boundary condition: alpha*dp/dt = u&n
Old   July 22, 2013, 05:39
Question boundary condition: alpha*dp/dt = u&n
Andreas Ruopp
andyru is on a distinguished road
Dear Foamers,
normally, on wall boundaries for example, we must guarantee:
0 = U&n
where U is the velocity vector and n is the patch normal surface vector,
and the inner product has to be zero.
On a specific patch, I impose a diriclet boundary condition for the pressure.
For the velocity, I want to have:
alpha*dp/dt = U*n
I'm thinking about treating this patch as a modified free slip wall, but I'm wondering, how I can impose that mentioned boundary condition for U.
A slip wall uses in the end the basicSymmetryFvPatchField method, resulting in 0 = u&n
tmp<vectorField> nHat = this->patch().nf();
00116
00117     const Field<Type> iF(this->patchInternalField());
00118
00119     Field<Type>::operator=
00120     (
00121         (iF + transform(I - 2.0*sqr(nHat), iF))/2.0
00122     );
00123
00124     transformFvPatchField<Type>::evaluate();
For example if the cell value next to patch face is in 2D:
if=(1 1)
and nf is normal patch face vector pointing outward with
nf=(0 1)
Then evaluate returns a vector
(1 0)
resulting from,
((1 1) + transform([1 0;0 1] - [0 0 ;0 2],(1 1)])/2
ok.
And then
n&U is zero, hence 0=1*0+0*0
and
0 = U&n is fullfilled.
But how can
alpha*dp/dt = U*n
be achieved?
Any help will be appreciated!
Best regards,
Andy
andyru is offline   Reply With Quote
Old   July 23, 2013, 05:59
Default After a long night... direction mixed boundary condition approach, maybe?!
Andreas Ruopp
here my update, maybe things become clearer:
since I want to impose
alpha*dp/dt = U*n
where alpha*dp/dt represents a velocity term for that boundary in normal direction to that face, I was digging in under
.../src/finiteVolume/fields/fvPatchFields/basic/
where I found directionMixedFvPatchField.C
If I understand it right:
For a vector (like in my case it is velocity U), this boundary condition is decomposed into the normal and tangential component.
I have to set three reference values for that boundary condition (good description under http://www.cfd-online.com/Forums/ope...tml#post316165:
1) refValue = which will be the value on face in normal direction
2) refGradient = will be enforced in the patch tangential direction
3) valueFraction = which is the symmetrical Tensor, which I have to define for transformation purposes
I think this b.c. is a good starting point for manipulating my boundary condition for U...
Best regards,
Andy
boundary, condition, slip, treament, wall
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
