Custom boundary condition: unexpected behavior with chtMultiRegionFoam
Old   January 28, 2014, 12:51
Post Custom boundary condition: unexpected behavior with chtMultiRegionFoam
Vincent Leroy
leroyv is on a distinguished road
Dear OpenFOAM users,
I recently wrote a simple custom boundary condition which computes the fluid velocity at the wall using a formula of the type:
v = f(rho) * normal
While my code yields the expected results using the rhoPimpleFoam solver, everything is messed up when using it with chtMultiRegionFoam, even though I use the exact same parameters for the BC. The near-wall velocity has an inverted orientation, and the upstream flow has a stagnation point, even if the wall velocity is oriented downstream. This is obviously a physical and numerical nonsense ...
Is there something in particular that should be taken care of when using chtMultiRegionFoam with custom BCs?
Parameters with rhoPimpleFoam:
squareWall
        type            pyrolysisVelocity;
        refValue        0.001;
        massPR          0.001;
        rhoS            -1;
        rhoName         rho;
Result: https://www.dropbox.com/s/n7cfws80w3...Foam_outer.png
With chtMultiRegionFoam:
fluid_to_solid
                refValue 0.001;
                massPR 0.001;
                rhoS -1;
                rhoName rho;
Result: https://www.dropbox.com/s/8t2re4piih...Foam_outer.png
leroyv is offline   Reply With Quote
Old   January 29, 2014, 11:42
Post Update
Vincent Leroy
A little progress update: I went through the code and did some additional debugging. The coordinates of velocity on the patch seem to be computed correctly: I checked the values in the output files.
The results with a surfaceNormalFixedValue BC are okay:
https://www.dropbox.com/s/zui2qaz9tz...FixedValue.png
I'm guessing something wrong happens when running the updateCoeffs() method, maybe I shouldn't use the fixedValueFvPatchVectorField::operator==() member function?
Old   January 30, 2014, 09:30
Post Update
Vincent Leroy
I ran an additional test using swak4foam:
fluid_to_solid
        type groovyBC;
        valueExpression "- 0.001 * normal()";
It gave nearly the same result as obtained with chtMultiRegionFoam:
https://www.dropbox.com/s/0yjr5vca1y..._swak4foam.png
Old   February 1, 2014, 07:49
Post Update
Vincent Leroy
I computed the mass flux using the patchIntegrate utility.
Solver: chtMultiRegionFoam (using BCs for isothermal flow)
Inlet mass flux: 0.000811 kg/s
1. BC: surfaceNormalFixedValue, -0.001
fluid_to_solid mass flux: 0.000463 kg/s
Outlet mass flux: 0.00127 kg/s
2. BC: groovyBC, "- 0.001 * normal()"
fluid_to_solid mass flux: <something>e-20 = 0 kg/s
Outlet mass flux: 0.000811 kg/s
Mass conversation seems to be okay. Something might be going wrong with the phi field, because the value of U at the boundary seems to be fine:
        value           nonuniform List<vector>
40
(0.001 0 0)
(0 -0.001 0)
(0.001 0 0)
(0.001 0 0)
(0.001 0 0)
(0.001 0 0)
(0.001 -0 0)
(0.001 -0 0)
(0.001 -0 0)
(0.001 -0 0)
(0.001 -0 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(0 -0.001 0)
(0 0.001 0)
(-0.001 -0 0)
(0 -0.001 0)
(-0.001 -0 0)
(-0.001 -0 0)
(-0.001 -0 0)
(-0.001 -0 0)
(-0.001 0 0)
(-0.001 0 0)
(-0.001 0 0)
(-0.001 0 0)
(0 0.001 0)
(-0.001 0 0)
Any idea of what that could be? I attached my case directory.
boundary condition, chtmultiregionfoam, swak4foam
Mathematical representation of fixedDisplacementZeroShear boundary condition Sargam05 OpenFOAM 14 January 11, 2022 06:55
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 12:02
Bug in fvc::grad() and periodic boundary condition JBUNSW OpenFOAM 3 November 15, 2012 03:09
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
