problem with -lgenericPatchFields in foam-extend-3.0
Old   May 7, 2014, 11:02
Default problem with -lgenericPatchFields in foam-extend-3.0
Laurent Orgogozo
Orgogozo is on a distinguished road
Dear foamers,
I am currently trying my home made solvers and utilities in foam-extend-3.0, and I encountered the following problem.
While compiling with foam-extend-3.0 a utility that compiles without problems with OF-2.2, I get the following error :
/usr/bin/ld: can't find -lgenericPatchFields
collect2: error: ld has returned 1 execution state code
make: *** [/homel/lorgo/foam/lorgo-3.0/applications/bin/linux64GccDPOpt/spatialMeanValue] Error 1
(a bit translate from the original french error message)
Does someone know a way to overcome this problem ?
Best regards,
Laurent
Orgogozo is offline   Reply With Quote
Old   May 8, 2014, 08:58
Tomislav Maric
tomislav_maric is on a distinguished road
Try using the locate command:
locate libgenericPatchFields
/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64Gcc++0xDPCustomProf/lib/libgenericPatchFields.so
/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64Gcc++0xDPDebug/lib/libgenericPatchFields.so
/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64Gcc++0xDPOpt/lib/libgenericPatchFields.so
/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPDebug/lib/libgenericPatchFields.so
/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libgenericPatchFields.so
/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc++0xDPOpt/lib/libgenericPatchFields.so
I've stripped the home folder parts, but there seems to be no such library in foam-extend-3.0. It might have a different name.
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Old   May 14, 2014, 04:16
Laurent Orgogozo
Dear Tomislav, dear foamers,
I tried to locate the libgenericPatchFields file in foam-extend-3.0 and I get the same result than you Tomislav: this file is present only in OpenFOAM, not in foam-extend. Then I got stuck, because I can't identify another lib with Patch in its name in the libraries of the /foam/foam-extend-3.0/lib/linux64GccDPOpt directory.
I attached the utility that I tried to compile with foam-extend-3.0 (by the way it is designed to spatially average a volScalarField at each time of writing of data -as a postprocessing- and return the results as two columns : time, average). If someone manage to compile it, please let me know !
Best regards,
Laurent
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
problem in running icoFoam Alucard OpenFOAM 2 March 17, 2012 09:01
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
problem in running FoamX in Open FOAM Gaurav Main CFD Forum 3 May 10, 2006 05:06
problem about installing FOAM linux freshman Main CFD Forum 6 November 4, 2004 10:59
