Access to wal temperature with turbulentHeatFluxTemperature bc
Old   September 4, 2013, 07:38
Default Access to wal temperature with turbulentHeatFluxTemperature bc
nailzee is on a distinguished road
Hi Foamers,
I'm new to OpenFoam and have no idea about C++ but I was still able to put together a postprocessing tool that calculates the y+, u+ and T+ values in a channel stream for isothermal boundary conditions.
Now I'm trying to modify this tool so it can be used for isoflux boundary conditions but it failed to output the correct wall temperature.
The boundaryField for T in my final time folder looks like this
wall
type turbulentHeatFluxTemperature;
gradient uniform 33490.6;
heatSource flux;
q uniform 1000;
alphaEff kappaEff;
value nonuniform List<scalar>
125
3535.19
3535.37
3535.5
3535.54
3535.55
3535.56
3535.56
(several similar values)
but when I try to access in it in my tool with T.boundaryField() it displays following results
gradient uniform 0;
heatSource flux;
q uniform 1000;
alphaEff kappaEff;
125
3367.74
3367.92
3368.04
3368.09
3368.09
I noticed that the 33xx values are the ones of the first cell near the wall. So I tried the sample tool with
surfaceFormat raw;
surfaces
wall
type patch;
patches ("wall");
and it writes out the correct values for the wall. Then I tried to look up how the sample tool accesses the values of a surface but couldn't find anything with my non existing C++ knowledge.
Anyone has any idea how to do that?
Thanks in advance.
nailzee is offline   Reply With Quote
Old   January 21, 2014, 12:40
Joachim Herb
jherb is on a distinguished road
I am not sure, but perhaps this helps: http://www.cfd-online.com/Forums/ope...hi-patchi.html
Are you really using always the surface values? Is your tool using boundary.correct() (or what happens if you add it)?
jherb is offline   Reply With Quote
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Can we have access temperature derivatives??? behrang2009 Fluent UDF and Scheme Programming 0 July 29, 2010 19:21
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
An issue with temperature change in unsteady prob Ashok kumar FLUENT 1 January 13, 2009 04:34
