adding lift model to twoPhaseEulerFoam
Like Tree1Likes
  • 1 Post By dkxls
Old   September 17, 2013, 12:28
Default adding lift model to twoPhaseEulerFoam
mehrdad_kbg is on a distinguished road
Hi everybody,
I am trying to add new interfacial models to the twoPhaseEulerFoam solver. So, I started from lift force. I followed the drag model existing in the default solver and developed the lift model according to that. Every thing is exactly similar except the changes that I have made to implement the lift.
There was no issue when I compiled the interfacialModels library by doing wmake libso. But when I do a wmake for the solver I get the following error:
mytwoPhaseEulerFoam2.C.text+0x8a6b): undefined reference to `Foam::liftModel::New(Foam::dictionary const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam:haseModel const&, Foam:haseModel const&)'
mytwoPhaseEulerFoam2.C.text+0x8ab9): undefined reference to `Foam::liftModel::New(Foam::dictionary const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam:haseModel const&, Foam:haseModel const&)'
collect2: ld returned 1 exit status
make: *** [/home/mehrdad/OpenFOAM/mehrdad-2.1.1/platforms/linux64GccDPOpt/bin/mytwoPhaseEulerFoam2] Error 1
Do you have any idea what can cause this error?!
Thanks.
mehrdad_kbg is offline   Reply With Quote
Old   September 17, 2013, 12:53
dkxls's Avatar
Armin
dkxls will become famous soon enough
Without having your error message further checked: Did you set you linker options correctly and included:
 -L$(FOAM_USER_LIBBIN)
dkxls is offline   Reply With Quote
Old   September 17, 2013, 13:13
The "files" and "options" in the interfacial Models folder are attached:
liftModels/liftModel/liftModel.C
liftModels/liftModel/newLiftModel.C
liftModels/Tomiyama/Tomiyama.C
dragModels/dragModel/dragModel.C
dragModels/dragModel/newDragModel.C
dragModels/WenYu/WenYu.C
LIB = $(FOAM_USER_LIBBIN)/libEulerianInterfacialModels
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I../phaseModel/lnInclude
LIB_LIBS = \
-lphaseModel
Old   September 17, 2013, 13:25
dkxls's Avatar
Armin
The options file of your solver?
Old   September 17, 2013, 13:28
dkxls's Avatar
Armin
The options file of your solver should look something like this:
EXE_LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -lEulerianInterfacialModels \
    -lfiniteVolume \
    -lmeshTools \
    -lincompressibleTransportModels \
    -lphaseModel \
    -lkineticTheoryModel
Old   September 17, 2013, 13:34
here is my solver's option file:
EXE_INC = \
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
-IturbulenceModel \
-IinterfacialModels/lnInclude \
-IphaseModel/lnInclude \
-I$(LIB_SRC)/turbulenceModels \
-Iaveraging
EXE_LIBS = \
-lphaseModel \
-lfiniteVolume \
-lmeshTools
Old   September 17, 2013, 14:05
dkxls's Avatar
Armin
Sorry, these were just the simple guesses... Without checking in detail what goes wrong I don't have any ideas any more.
Old   September 17, 2013, 15:18
dkxls's Avatar
Armin
Something I just realized, you named the modified library the same as the original one.
I'm not sure if this work, at least I have never tried it to not even get into the situation of confusing them.
You could try something like:
LIB = $(FOAM_USER_LIBBIN)/libEulerianInterfacialModelsMod
and
EXE_LIBS = \
       -lphaseModel \
       -lEulerianInterfacialModelsMod \
       -lfiniteVolume \
       -lmeshTools
AleDR likes this.
Old   September 17, 2013, 16:08
You solved my problem.
Thank you veryyyyyyyyyyyyy much.
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 13:54
Is it possible to model natural convection in a 2D horizontal model in fluent caitoc FLUENT 1 May 5, 2014 13:32
About the dimension of Saffman-Mei particle lift force model haakon OpenFOAM Programming & Development 1 April 22, 2013 12:27
Adding new term in to K eqn of K-Epsilon turbuelnce model neeraj OpenFOAM Running, Solving & CFD 3 October 11, 2012 07:18
