Write scalar in file in every timeFolder
Old   September 19, 2013, 09:48
Default Write scalar in file in every timeFolder
Martin
RugbyGandalf is on a distinguished road
Dear Foam-Community,
i'd like to calculate the surface-area of the inlet-patch for a moving domain for every time step and write out the calculated value in a file in each time-folder.
For now i have the following code:
label inletPatchID = mesh.boundaryMesh().findPatchID("inlet");
    std::ofstream file("inlet_area.txt");
    file << gSum(mesh.magSf().boundaryField()[inletPatchID]) << std::endl;
    file.close();
But it only gives out a file in the case-directory (and overwrites it???)
Does anyone has any idea how to solve this?
Regards,
Martin
RugbyGandalf is offline   Reply With Quote
Old   September 19, 2013, 11:03
Bernhard
Bernhard is on a distinguished road
You will have to change the filename, something like this?
std::ofstream file(runTime.timeName(),"inlet_area.txt");
(This will probably not work due to string concatenation)
You also have alternative solutions
- Write to logfile (Info<<) and extract data afterwards from the log file (awk)
- Use a function object. functionObjects run during run time. I am not sure if you can do this with the default ones, but with the swak functionObjects by Bernhard Gschaider you can obtain this information easily for sure.
Bernhard is offline   Reply With Quote
Old   September 20, 2013, 08:29
Martin
Dear Bernhard,
thank you very much for your answer.
Unfortunately your hint did not work for me. The wmake-compiler gives out the following error:
CarreauYasudaIcoFoam.C:91:59: error: no suitable function for calling »std::basic_ofstream<char>::basic_ofstream(Foam::w ord, const char [15])«
the log-file hint migth work, although i'd really like to add it in the code.
Martin
Old   September 20, 2013, 08:37
Bernhard
The string concatenation is something I am not to sure about, this is something to dig into, maybe you could use something like "runTime.timeName().string()", but you wil have to experiment a bit.
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh elvis OpenFOAM Community Contributions 210 January 30, 2017 18:57
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
