Normal vector issue
Old   October 21, 2013, 02:34
Default Normal vector issue
Tayo
tayo is on a distinguished road
Hello all, I have two quick questions. I want to implement heat conduction equation in my phaseChange solver.
1.) How to get a normal vector, n in OF?
2.) How to obtain area A, of the cell face?
Here is what I've tried so far:
volVectorField gradT = fvc::grad(T);
volVectorField n = T.mesh().Sf()/T.mesh().magSf();   ;)
volScalarField A = T.mesh().magSf();  ;)
volScalarField q = A*(gradT & n);
I keep getting errors in the form of: "conversion from GeometricField, fvsPatchField, SurfaceMesh> to non-scalar type requested". I guess I'm not doing something right. Thank you for your help.
tayo is offline   Reply With Quote
Old   October 21, 2013, 06:37
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
not correct post
Tobi is offline   Reply With Quote
Old   October 21, 2013, 13:11
Tayo
Originally Posted by Tobi View Post
not correct post
Hi Tobi,
I don't understand what you mean; the gradient of a scalar field is a vector field, so grad(T) will give me a volVectorField. The code is actually works up to that point so I dont have a problem with gradT. Here is how I call my "T".
const volScalarField& T = alpha1_.db().lookupObject<volScalarField>("T");
My question is how do I compute the normal vector and facearea of the cell. Thanks
Old   October 21, 2013, 15:16
Tayo
Never mind, problem fixed . I simply used the wrong syntax in defining the normal and face area. Here's the correction. Thanks
vectorField n = T.mesh().Sf()/T.mesh().magSf();
scalarField A = T.mesh().magSf();
scalarField q = A*(gradT & n);
Old   October 22, 2013, 04:20
Tobi's Avatar
Tobias Holzmann
as I wrote later - I made a mistake because I had mixed up some Information. The Gradient of a scalar is a vector field with it s gradients of the components in x, y, z. So I was wrong in my first post.
And your error was the following signs:
Regards Tobi
How to get normal vector to the face? Viatcheslav Kulikov FLUENT 1 August 31, 2017 03:03
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 17:24
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
Normal stress?/ bowlderyu Main CFD Forum 1 October 28, 2008 21:57
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
