help needed for programming
Old   October 23, 2013, 02:33
Default help needed for programming
christy issac
chrisnitk is on a distinguished road
hi
iam christy, persuiing my mtech in thermal engg,Iam new here. For my mini project i have to solve Coutte flow using pressure correction technique.
i made my programme in C using staggered grid and used finite difference method.
when iam calculating my pressure value (i used float value) , since the values are too small it goes to a value of zero and in iterations it gives garbage value ....
how can i tackle too fine small values in cfd ??? is there any methodes or tools for that ...????
plz do help me
(u can send reply's to my mail also, issac_christy@yahoo.in)
chrisnitk is offline   Reply With Quote
Old   October 23, 2013, 12:44
Jace
zhengzh5 is on a distinguished road
Originally Posted by chrisnitk View Post
hi
plz do help me
hey, usually you would set a global constant (1e-15 used for OpenFOAM's "SMALL" constant) and compare this constant to your floats, such that if your float is smaller than the constant, the constant is used instead. Else if float is larger, use the float. that way you avoid division by very tiny numbers.
hope that helps.
zhengzh5 is offline   Reply With Quote
Old   October 28, 2013, 04:09
christy issac
sir
i changed my float declaration in to double . nw iam getting the values ... iam solving couette flow problem in anderson text book by pressure correction method ...
nw only i see ur reply . thanks for helping me .. i will try dat ..
iam uploading my program here .. it wil b greatful if u can find any errors in that...
iam sory, if iam bothering u ... bt this is my first program , and iam very nervous abt it ............. thanking you
couettenew2.c
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 12:39
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 11:51
compiling firefoam Farshad_Noravesh OpenFOAM 27 December 24, 2012 04:21
libscotch-5.1.so needed for DPOpt flowris OpenFOAM Installation 6 May 2, 2012 16:46
a dissertation in ETD needed very much LiQiang Main CFD Forum 0 March 11, 2005 03:09
