Eclipse & OpenFoam
Like Tree1Likes
Old   February 20, 2014, 09:59
Default Eclipse & OpenFoam
maybee is on a distinguished road
hi,
I just want to run the "multiphaseEulerFoam" solver without any case applied to it. I followed the manual in the following link:
http://openfoamwiki.net/index.php/Ho...pse#Thanks_to_..
I have done the following steps:
1.Download Eclipse Kepler: www.eclipse.org/downloads/ and unpack the file
2.Start Eclipse and update it in Help -> Install New Software... ; Add ... with http://download.eclipse.org/tools/cdt/releases/galileo/
3. Configure the interface in Window -> Show View -> C/C++ for C++ projects
4. Create a new project Files -> New -> C++ Project. I chose the solver folder (since solver is a application) for the location and for the project name i chose the solver name.
5. Right click my project and chose properties:
->C/C++ build: Deactivate the default build command and type in "wmake".
->C/C++ General->PathsandSymbols: Included all necessary folders.
Problem:
When I build the project I get the error:
wmake error: environment variable $WM_OPTIONS not set
When I try to run the ".c file" I get the message
Launch failed.Bindary not found!
Why can t I run the solver and how can I solve this problems?
greetings
maybee
maybee is offline   Reply With Quote
Old   February 23, 2014, 10:22
Wouter van der Meer
wouter is on a distinguished road
hello maybee,
a google search on openfoam eclips gave me this:
http://openfoamwiki.net/index.php/Ho...M_with_Eclipse
I used this and it works fine for me.
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   February 23, 2014, 11:50
hi, this is the same manual I also used and posted the link (see first link of my first post) - still I get the described error message.
Old   February 23, 2014, 14:53
Wouter van der Meer
Hello maybee,
You need to start eclipse from a terminal window where OF is sourced or use another command for wmake like described in one of the other links you get when googleing.
Hope this helps more
Wouter
Old   February 24, 2014, 06:45
hi,
since I installed Eclipse like described here
I can t run it in the terminal, only getting the error message:
application »eclipse« currently not installed. You can install it by:
sudo apt-get install eclipse-platform
Furthermore I added to the .bashrc file located in /opt/openfoam221/etc the line
source $opt/openfoam221/etc/bashrc
like described here
http://www.cfd-online.com/Forums/ope...-pisofoam.html
Unfortunately I could not run the command
source $opt/.bashrc
or even when after changing the terminals path to "/opt/openfoam221/etc"
source $etc/.bashrc
I get the error message:
bash: /.bashrc: File or Folder not found although the file exists.
Total-Result: I still can t build my project, still getting :
Build:
Run:
greetings maybee
Old   February 24, 2014, 15:53
Wouter van der Meer
hello maybee,
I do not know enough of linux to help you like wyldckat, but maybe I can help you a little. In the reference you gave there is mention to add the source ... to ~/.bashrc nothing to do with openfoam, just the bash file that is started when you start a terminal window. If you add the source ... to the end of this file and start a new terminal window you should be able to run wmake in the directory where Make is.
Hope this helps
wouter
Old   February 25, 2014, 05:25
hi wouter,
I added now
to the file bash.bahsrc which is located in "/etc". Still I can t run my project neither in KDev4 nor in Eclipse. However running "wmake" in the terminal is no problem though. It is just not comfortable debugging my code with the terminal.
Other "bach files" available after search are:
bash.bashrc in /usr/share/doc/adduser/examples/adduser.local.conf.examples
dot.bashrc in /usr/share/base-files
dot.bashrc in /usr/share/doc/adduser/examples/adduser.local.conf.examples/skel
Old   February 25, 2014, 14:54
Wouter van der Meer
hello Maybee,
As I told you before I am no expert,but here is a guide step by step.
first step:
in terminal:
cd ~
second step:
gedit .bashrc
in this file at the bottom add:
source /opt/openfoam221/etc/bashrc
save and close
close terminal
next step
open terminal
type:
eclipse
This should start eclipse and you should be able to use wmake from eclipse as described
Hope this helps
Wouter
Old   February 26, 2014, 04:21
bfa
Björn Fabritius
bfa is on a distinguished road
Hi maybee,
where did you install eclipse to? because the fact that you can't start eclipse from the terminal suggests that the path is not set correctly. Quoting from the wiki guide: "[...] start Eclipse from the terminal after setting the path variable."
If you type
which eclipse
in the terminal and it comes back with an empty line, linux is not able to find the executable. If you unpacked it to something like $HOME/eclipse, you need to either add the following line to your .bashrc file:
export PATH="$PATH:$HOME/eclipse/"
or you need to start it using
$HOME/eclipse/eclipse
If you sourced OpenFOAM and then start eclipse in one of the ways described above, you should be able to compile your code.
Hope that helps!
Bjoern
bfa is offline   Reply With Quote
Old   February 26, 2014, 12:37
@ wouter: Still does not work. Furthermore I already added
to the right .bashrc file
Still I get the error:
@bfa:
Ok I can start now Eclipse after putting the folder with the executable into the home folder and adding the lines you described to the bash file. Now I get the error
/opt/openfoam221/wmake/wmake all
/opt/openfoam221/wmake/wmake: 181: /opt/openfoam221/wmake/wmake: ./Allwmake: Permission denied
when I want to build my project.
Old   February 26, 2014, 13:35
bfa
Björn Fabritius
You need to put your own code in a folder to which you have writing permission. /opt/openfoam is certainly write-protected. I guess your admin has installed OpenFOAM there for you.
Follow the instructions here
http://www.csc.fi/english/research/s...penfoam/modsol
to find out, how to create the directories in your $HOME folder, which files you need to compile a solver and so on. Also put your Eclipse project files there.
(Linux is based on a restrictive rights management, so a "normal" user cannot break the system. But you have unlimited access to anything in your $HOME folder.)
Old   February 27, 2014, 21:18
Jianzhi Li
epi_c is on a distinguished road
Send a message via Skype™ to epi_c
Hello maybee,
I also used the Eclipse following the instruction:
And it works, Here are my steps:
1.Download "Eclipse IDE for C/C++ Developers" from http://www.eclipse.org/downloads/
2.Untar the file getting an folder "eclipse", move the folder to /usr/lib/ using root access.
3.Make a link so that eclipse can run in a terminal:
cd /usr/bin
sudo ln -s /usr/lib/eclipse/eclipse
4.Copy the slover folder to $HOME, so you can have the permission to edit them without root access.
epi_c is offline   Reply With Quote
Old   February 28, 2014, 04:15
@epi_c: I have done as you described. Also I have added the line
export PATH="$PATH:$usr/lib/eclipse/"
OR
export PATH="$PATH:$usr/lib/eclipse/eclipse"
into the .bashrc file.
But unfortunately I get the same error message as before:
Old   February 28, 2014, 05:50
Jianzhi Li
@maybee: Ok, I don't know what's your problem really is. If you don't mind, try what I did as follows (System information: Ubuntu 12.04 LTS, 32bit):
Tips: You don't have to edit the .bashrc file following my way, It is suggested that you delete your changes in .bashrc file befor installation.
1. Download JRE which Eclipse needs from
http://www.oracle.com/technetwork/ja...s-1880261.html, the package suit for me is “jre-7u51-linux-i586.tar.gz”
2. Download "Eclipse IDE for C/C++ Developers" from http://www.eclipse.org/downloads/, the package is “eclipse-cpp-kepler-SR1-linux-gtk.tar.gz” (I put above two packages in $HOME/Downloads)
3. Install and set JRE:
cd /usr/lib
sudo mkdir java (The directory that JRE to be installed)
cd java
sudo mv $HOME/Downloads/jre-7u51-linux-i586.tar.gz .
sudo tar xzf jre-7u51-linux-i586.tar.gz
sudo rm jre-7u51-linux-i586.tar.gz (To save space)
sudo update-alternatives --install /usr/bin/java java /usr/lib/java/jre1.7.0_51/bin/java 1
sudo update-alternatives --set java /usr/lib/java/jre1.7.0_51/bin/java
4. Install Eclipse:
sudo mv $HOME/Downloads/eclipse-cpp-kepler-SR1-linux-gtk.tar.gz /usr/lib
cd /usr/lib
sudo tar xzf eclipse-cpp-kepler-SR1-linux-gtk.tar.gz
sudo rm eclipse-cpp-kepler-SR1-linux-gtk.tar.gz
cd /usr/bin
5. Type "java --version" in a terminal to test whether JRE is installed correctly or not,
6. Type "which eclipse" to test whether you can run eclipse in a terminal or not
7. Run eclipse in a terminal, then you can do as http://openfoamwiki.net/index.php/Ho...M_with_Eclipse
Old   February 28, 2014, 06:27
hi thx a lot for the help,
but I still have some problems even with your manual.
First of all the second package is
eclipse-standard-kepler-SR1-linux-gtk.tar.gz
when I download it.
Secondly, when I run the command
I get the error:
Missing destination-file operator behind »/home/USER/Downloads/jre-7u51-linux-i586.tar.gz“
Old   February 28, 2014, 06:42
Jianzhi Li
Ok, the first problem, you download the standard eclipse package, then after finishing my manual, you should install CDT plugin by hand. Or you should download from http://www.eclipse.org/downloads/pac...pers/keplersr1
The second, "sudo mv $HOME/Downloads/jre-7u51-linux-i586.tar.gz ."
There is a "dot" that represent the CWD, type mv --help for more information
Old   February 28, 2014, 08:57
Sorry for my fail ,
I' ll check this tomorrow or sunday.
have a nice weekend.
Old   February 28, 2014, 09:44
Smile
  #18
Jianzhi Li
I just tried on my virtual machine with exact the same system (Ubuntu 12.04 LTS, 32bit), and it works, below are my command logs:
fran@lico:~$ cd /usr/lib/
fran@lico:/usr/lib$ sudo mkdir java
[sudo] password for fran:
fran@lico:/usr/lib$ cd java/
fran@lico:/usr/lib/java$ sudo mv $HOME/Downloads/jre-7u51-linux-i586.tar.gz .
-alternative command$ sudo mv $HOME/Downloads/jre-7u51-linux-i586.tar.gz /usr/lib/java))
fran@lico:/usr/lib/java$ sudo tar xzf jre-7u51-linux-i586.tar.gz
fran@lico:/usr/lib/java$ sudo rm jre-7u51-linux-i586.tar.gz
fran@lico:/usr/lib/java$ sudo update-alternatives --install /usr/bin/java java /usr/lib/java/jre1.7.0_51/bin/java 1
update-alternatives: using /usr/lib/java/jre1.7.0_51/bin/java to provide /usr/bin/java (java) in auto mode.
fran@lico:/usr/lib/java$ sudo update-alternatives --set java /usr/lib/java/jre1.7.0_51/bin/java
fran@lico:/usr/lib/java$ java --version
Unrecognized option: --version
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
fran@lico:/usr/lib/java$ java -version
java version "1.7.0_51"
Java(TM) SE Runtime Environment (build 1.7.0_51-b13)
Java HotSpot(TM) Client VM (build 24.51-b03, mixed mode)
fran@lico:/usr/lib/java$ sudo mv $HOME/Downloads/eclipse-cpp-kepler-SR1-linux-gtk.tar.gz /usr/lib
fran@lico:/usr/lib/java$ cd /usr/lib/
fran@lico:/usr/lib$ sudo tar xzf eclipse-cpp-kepler-SR1-linux-gtk.tar.gz
fran@lico:/usr/lib$ sudo rm eclipse-cpp-kepler-SR1-linux-gtk.tar.gz
fran@lico:/usr/lib$ cd /usr/bin/
fran@lico:/usr/bin$ sudo ln -s /usr/lib/eclipse/eclipse
fran@lico:/usr/bin$ which eclipse
/usr/bin/eclipse
fran@lico:/usr/bin$ eclipse
I made a mistake, the command "java --version" should replace with "java -version".
While using eclipse, some setup files will be written in the project folder, so it is suggested that you copy the solver's source file folder to $HOME/***, i.e. $HOME/OpenFOAM. May you success!
Old   March 2, 2014, 12:18
Hi again,
this worked now fine for me and I m able to start eclipse. When building my project now (the solver) I get the output
8:09:08 **** Incremental Build of configuration Debug for project SolverSQMOM ****
18:09:08 Build Finished (took 87ms)
I don t understand this since I m the owner of file "Allwmake" located in "/opt/openfoam221/".
If I try to build I get
Launch failed. Binary not found!
greetings maybee
Old   March 2, 2014, 20:23
Jianzhi Li
Morning,
As I mentioned before, while using eclipse some setting files with prefix "." (.project, .cproject) will be written into project folder, and, when execute command like wmake, new files like "*.dep, *.o" will be written into project folder too. So, even you are the owner of Allwmake (which means that you can execute Allwmake without root access), the command wmake called in the script will need root access to write files into directory (except $HOME).
The solutions can be:
1. Launch eclipse in a terminal with command "sudo eclipse", then you can have root access during the whole time.
or:
2. Copy the project folder into somewhere in $HOME, so you can run eclipse in a terminal with command "eclipse".
....As I know, compiling a single solver has nothing to do with the script Allwmake, you should remove unrelated files like Allwmake away. I found a Allwmake under applications/solvers/incompressible/simpleFoam, and its only function is to compile solvers SRFSimpleFoam and porousSimpleFoam.
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 16:52
[Gmsh] gmsh 2.6.0 conversion to OpenFoam 160 rosswin OpenFOAM Meshing & Mesh Conversion 0 March 5, 2013 07:34
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
