November 26, 2013, 11:32 |
IOStream Code - dsmcParcelIO.C
Craig White
Rep Power: 12 |
I have been developing the DSMC code to run with vibrational energy and this involves adding a scalarField of vibrational energies (one energy for each mode). My code runs well in serial, but I am getting segmentation faults when running in parallel: [1] #3 cfree in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 cfree in "/lib/x86_64-linux-gnu/libc.so.6" [1] #4 Foam::dsmcParcel::dsmcParcel(Foam:olyMesh const&, Foam::Istream&, bool) in "/lib/x86_64-linux-gnu/libc.so.6" [0] #4 Foam::dsmcParcel::dsmcParcel(Foam:olyMesh const&, Foam::Istream&, bool) in "/home/craig/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libdsmcPolyStrath.so" [1] #5 in void Foam::Cloud<Foam::dsmcParcel>::move<Foam::dsmcParc el::trackingData>(Foam::dsmcParcel::trackingData&, double)"/home/craig/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libdsmcPolyStrath.so" [0] #5 void Foam::Cloud<Foam::dsmcParcel>::move<Foam::dsmcParc el::trackingData>(Foam::dsmcParcel::trackingData&, double) in "/home/craig/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/li in "/home/craig/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lb/libdsmcPolyStrath.so" I'm quite sure it's an issue with my code in dsmcParcelIO.C - I have created a IOField<scalarField> for the vibrational energy that successfully writes out the vibrational energies: Code:
IOField<vector> U(c.fieldIOobject("U", IOobject::NO_READ), np); IOField<scalar> ERot(c.fieldIOobject("ERot", IOobject::NO_READ), np); IOField<scalarField> EVib(c.fieldIOobject("EVib", IOobject::NO_READ), np); IOField<label> typeId(c.fieldIOobject("typeId", IOobject::NO_READ), np); IOField<label> newParcel(c.fieldIOobject("newParcel", IOobject::NO_READ), np); IOField<label> classification(c.fieldIOobject("classification", IOobject::NO_READ), np); IOField<label> trackingNumber(c.fieldIOobject("trackingNumber", IOobject::NO_READ), np); label i = 0; forAllConstIter(dsmcCloud, c, iter) { const dsmcParcel& p = iter(); U[i] = p.U(); ERot[i] = p.ERot(); EVib[i] = p.EVib(); typeId[i] = p.typeId(); newParcel[i] = p.newParcel(); classification[i] = p.classification(); trackingNumber[i] = p.trackingNumber(); i++; } U.write(); ERot.write(); EVib.write(); typeId.write(); newParcel.write(); classification.write(); trackingNumber.write(); Code:
IOField<vector> U(c.fieldIOobject("U", IOobject::MUST_READ)); c.checkFieldIOobject(c, U); IOField<scalar> ERot(c.fieldIOobject("ERot", IOobject::MUST_READ)); c.checkFieldIOobject(c, ERot); IOField<scalarField> EVib(c.fieldIOobject("EVib", IOobject::MUST_READ)); c.checkFieldIOobject(c, EVib); IOField<label> typeId(c.fieldIOobject("typeId", IOobject::MUST_READ)); c.checkFieldIOobject(c, typeId); IOField<label> newParcel(c.fieldIOobject("newParcel", IOobject::MUST_READ)); c.checkFieldIOobject(c, newParcel); IOField<label> classification(c.fieldIOobject("classification", IOobject::MUST_READ)); c.checkFieldIOobject(c, classification); IOField<label> trackingNumber(c.fieldIOobject("trackingNumber", IOobject::MUST_READ)); c.checkFieldIOobject(c, trackingNumber); label i = 0; forAllIter(dsmcCloud, c, iter) { dsmcParcel& p = iter(); p.U_ = U[i]; p.ERot_ = ERot[i]; p.EVib_ = EVib[i]; p.typeId_ = typeId[i]; p.newParcel_= newParcel[i]; p.classification_ = classification[i]; p.trackingNumber_ = trackingNumber[i]; i++; } Any help would be appreciated here. Thanks, Craig |
November 27, 2013, 10:44 |
Craig White
Rep Power: 12 |
Could it be a problem with my Ostream operator function? The problem only seems to happen when a particle hits a boundary (even a processor patch).
Foam::Ostream& Foam::operator<< ( Ostream& os, const dsmcParcel& p ) { if (os.format() == IOstream::ASCII) { os << static_cast<const particle&>(p) << token::SPACE << p.U_ << token::SPACE << p.ERot_ << token::SPACE << p.EVib_ << token::SPACE << p.typeId_ << token::SPACE << p.newParcel_ << token::SPACE << p.classification_ << token::SPACE << p.trackingNumber_; } else { os << static_cast<const particle&>(p); os.write ( reinterpret_cast<const char*>(&p.U_), sizeof(p.U_) + sizeof(p.ERot_) + sizeof(p.typeId_) + sizeof(p.newParcel_) + sizeof(p.classification_) + sizeof(p.trackingNumber_) ); os << p.EVib_; } // Check state of Ostream os.check ( "Foam::Ostream& Foam::operator<<" "(Foam::Ostream&, const Foam::dsmcParcel&)" ); return os; } |
December 2, 2013, 12:14 |
Craig White
Rep Power: 12 |
I got this working, so I'll post my solution here in the hope it helps someone in the future.
I had to move the EVib_ entry to the end of the list of things to be initialised, which initially looked like: Code:
inline Foam::dsmcParcel::dsmcParcel ( const polyMesh& mesh, const vector& position, const vector& U, const scalar ERot, const List<scalar>& EVib, const label cellI, const label tetFaceI, const label tetPtI, const label typeId, const label newParcel, const label classification, const label trackingNumber ) : particle(mesh, position, cellI, tetFaceI, tetPtI), U_(U), ERot_(ERot), EVib_(EVib), typeId_(typeId), newParcel_(newParcel), classification_(classification), trackingNumber_(trackingNumber) {} Code:
inline Foam::dsmcParcel::dsmcParcel ( const polyMesh& mesh, const vector& position, const vector& U, const scalar ERot, const List<scalar>& EVib, const label cellI, const label tetFaceI, const label tetPtI, const label typeId, const label newParcel, const label classification, const label trackingNumber ) : particle(mesh, position, cellI, tetFaceI, tetPtI), U_(U), ERot_(ERot), typeId_(typeId), newParcel_(newParcel), classification_(classification), trackingNumber_(trackingNumber), EVib_(EVib) {} Code:
Foam::dsmcParcel::dsmcParcel ( const polyMesh& mesh, Istream& is, bool readFields ) : particle(mesh, is, readFields), U_(vector::zero), ERot_(0.0), typeId_(-1), newParcel_(0), classification_(0), trackingNumber_(0), EVib_(0) { if (readFields) { if (is.format() == IOstream::ASCII) { is >> U_; ERot_ = readScalar(is); typeId_ = readLabel(is); newParcel_ = readLabel(is); classification_ = readLabel(is); trackingNumber_ = readLabel(is); is >> EVib_; } else { is.read ( reinterpret_cast<char*>(&U_), sizeof(U_) + sizeof(ERot_) + sizeof(typeId_) + sizeof(newParcel_) + sizeof(classification_) + sizeof(trackingNumber_) ); is >> EVib_; } } // Check state of Istream is.check ( "Foam::dsmcParcel::dsmcParcel" "(" "const Cloud<dsmcParcel>& cloud, " "Foam::Istream&, " "bool" ")" ); } Code:
Foam::Ostream& Foam::operator<< ( Ostream& os, const dsmcParcel& p ) { if (os.format() == IOstream::ASCII) { os << static_cast<const particle&>(p) << token::SPACE << p.U() << token::SPACE << p.ERot() << token::SPACE << p.typeId() << token::SPACE << p.newParcel() << token::SPACE << p.classification() << token::SPACE << p.trackingNumber() << token::SPACE << p.EVib(); } else { os << static_cast<const particle&>(p); os.write ( reinterpret_cast<const char*>(&p.U()), sizeof(p.U()) + sizeof(p.ERot()) + sizeof(p.typeId()) + sizeof(p.newParcel()) + sizeof(p.classification()) + sizeof(p.trackingNumber()) ); os << p.EVib(); } // Check state of Ostream os.check ( "Foam::Ostream& Foam::operator<<" "(Foam::Ostream&, const Foam::dsmcParcel&)" ); return os; } |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 04:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 11:02 |
Error in CFX Solver | Leuchte | CFX | 5 | November 6, 2010 06:12 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
