December 8, 2013, 04:21 |
boundary mesh
#1 | |
Rep Power: 14 |
hi,
I have read: http://www.openfoam.org/docs/user/mesh-description.php Questions: 1. The boundary mesh are the faces of the outer cells that together build the border of the geometry? 2. Out of the link above: Quote:
December 8, 2013, 04:54 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Maybee,
Ad. 1: Yes. Ad. 2: It simply means that you need to mesh the entire volume, which you consider, and you are not allowed to have overlapping faces. I.e. you would not consider a football to be closed, if you put a hole in it. The sum of the surface normal vectors on a closed football is per definition 0, but with the whole (only consider the outside of the ball for the sake of the argument), you will have an error, which is of the size of the area of the hole. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
December 8, 2013, 05:37 |
#3 | |
Rep Power: 14 |
hi,
thx. Quote:
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
