How to bring OpenFoam 2.1 viscosityModel to OpenFoam 2.2
Old   January 20, 2014, 03:37
Question How to bring OpenFoam 2.1 viscosityModel to OpenFoam 2.2
Marvin
Marvin_Rauch is on a distinguished road
I'm trying to bring my viscosityModel from OpenFoam 2.1 to OpenFoam 2.2. I was told it worked with 2.1. So I have two questions.
Can I simply install OF2.1 besides OF2.2 to check if the viscosity Model really works?
The error that comes when typing wmake in OF 2.2 is
marvin@marvin-VirtualBox:~/OpenFOAM/marvin-2.2.1/src/transportModels/viscoelastic$ wmake
SOURCE=viscoelasticLaws/LPTT/LPTT.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam221/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/LPTT.o
viscoelasticLaws/LPTT/LPTT.C: In member function ‘virtual void Foam::LPTT::correct()’:
viscoelasticLaws/LPTT/LPTT.C:112:66: error: no match for ‘operator-’ in ‘Foam:perator-(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::Tensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = Foam::Tensor<double>]((*(const Foam::tmp<Foam::GeometricField<Foam::Tensor<double >, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Tensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]((*(const Foam::tmp<Foam::GeometricField<Foam::Tensor<double >, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator+(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::Tensor<double>, Type2 = Foam::Tensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::typeOfSum<Type, Form>::type = Foam::Tensor<double>]((*(const Foam::tmp<Foam::GeometricField<Foam::Tensor<double >, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator&(const Foam::GeometricField<Foam::SymmTensor<double>, PatchField, GeoMesh>&, const Foam::GeometricField<Foam::SymmTensor<double>, PatchField, GeoMesh>&) [with PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]((*(const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>*)(&((Foam::LPTT*)this)->Foam::LPTT::tau_)))))))))))) - Foam::fvm::Sp(const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::SymmTensor<double>]((*(const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>*)(&((Foam::LPTT*)this)->Foam::LPTT::tau_)))’
viscoelasticLaws/LPTT/LPTT.C:112:66: note: candidates are:
and then there are hundreds of canditates listed
at the end it says:
make: *** [Make/linux64GccDPOpt/LPTT.o] Error 1
I can't find that file LPTT.o. What can I do to debug? I already looked into the LPTT.c file but don't see what I should change in line 112 :66
.................................................. .......................................row 66
.................................................. ..........................................v
line 112: - fvm::Sp( epsilon_ / etaP_ * tr(tau_) + 1/lambda_, tau_ )
Has anyone experience with bringing models from one version to a newer version? Is there any changelog or comparable document?
Thanks a lot for your help
Marvin_Rauch is offline   Reply With Quote
Old   January 20, 2014, 08:55
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
at the end it says:
Can you post the whole equation you solve in the model? From the output one can deduce that the problem is in minus in front of fvm::Sp(...). But to see the real problem one needs to see the whole equation.
alexeym is offline   Reply With Quote
Old   January 24, 2014, 13:13
Default Whole equation
Marvin
Thanks, I haven't been able to reach my OpenFOAM pc. Here is the equation:
// * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * //
tmp<fvVectorMatrix> LPTT::divTau(volVectorField& U) const
// dimensionedScalar etaPEff = (1 + 1/epsilon_)*etaP_;
dimensionedScalar etaPEff = etaP_;
return
fvc::div(tau_/rho_, "div(tau)")
- fvc::laplacian(etaPEff/rho_, U, "laplacian(etaPEff,U)")
+ fvm::laplacian( (etaPEff + etaS_)/rho_, U, "laplacian(etaPEff+etaS,U)")
void LPTT::correct()
// Velocity gradient tensor
volTensorField L = fvc::grad( U() );
// Convected derivate term
volTensorField C = tau_ & L;
// Twice the rate of deformation tensor
volSymmTensorField twoD = twoSymm( L );
// Stress transport equation
tmp<fvSymmTensorMatrix> tauEqn
fvm::ddt(tau_)
+ fvm::div(phi(), tau_)
etaP_ / lambda_ * twoD
+ twoSymm( C )
- zeta_ / 2 * ( (tau_ & twoD) + (twoD & tau_) )
tauEqn().relax();
solve(tauEqn);
I hope this helps you to help me with my problems.
Thanks in advance!
Old   January 25, 2014, 07:40
Alexey Matveichev
From the error message and code I can suppose that OpenFOAM doesn't know how to subtract Tensor from SymmTensor. In the RHS of the equation all terms are SymmTensors except -fvm::Sp(...).
And answering one of your first questions: yes, you can install 2.1.x along with 2.2.2.
changelog, lptt, models
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
openfoam 2.2 force coefficients 0 mihaipruna OpenFOAM Running, Solving & CFD 9 February 19, 2017 08:32
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
