Error:/usr/bin/ld: cannot find -lreynoldsnet collect2: error: ld returned 1 exit stat |
January 17, 2021, 21:55 |
Rep Power: 5 |
Hi, everyone.
I tried to compile a new lib but it met the error that "/usr/bin/ld: cannot find -lreynoldsnet collect2: error: ld returned 1 exit status". The lib I tried to compile is a modified incompressible lib. When compiling this lib, it should call another user defined lib, "reynoldsnet" lib. I have succeeded in compiling reynoldsnet lib. In user platforms(located in "/home/cbq/OpenFOAM/cbq-4.1/platforms/linux64GccDPInt32Opt/lib"), this lib can be seen. To call this lib, the "option" file in "Make" folder is written as following: EXE_INC = \ -I../turbulenceModels/lnInclude \ -I../turbulenceModles/reynoldsNet/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude LIB_LIBS = \ -lincompressibleTransportModels \ -lturbulenceModels \ -lfiniteVolume \ -lmeshTools \ -lreynoldsnet But when I type "wmake" in terminal, it occurred an error said "cannot find -lreynoldsnet collect2: error: ld returned 1 exit stat". Could anyone tell me how to solve this problem? Thanks a lot. |
January 18, 2021, 14:03 |
Rep Power: 14 |
Just a quick question - what name did you give the "reynoldsnet" lib? In your make file, the line
-lreynoldsnet |
Debug version of OpenFOAM-1.6 | alundilong | OpenFOAM Installation | 20 | May 11, 2023 07:31 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 05:41 |
