firefoam - use for non reactive mixing or no combution
Like Tree1Likes
  • 1 Post By babakflame
Old   February 12, 2014, 23:52
Default firefoam - use for non reactive mixing or no combution
Krishna
rkc.cfd is on a distinguished road
I want to simulate non reactive mixing and found that firefoam has the required capabilities. I like to know how can I drop the extra enthalpy equation and use the nocombustion.C source file.
Cheers,
Krishna
rkc.cfd is offline   Reply With Quote
Old   February 13, 2014, 04:56
Bobby
babakflame is on a distinguished road
greetings Krishna
It is very easy. If you are using O.F. 2.2. version . you have to to change the line in combustion properties file to noCombustion.
Also this choice is available in reactingFoam solver.
rkc.cfd likes this.
babakflame is offline   Reply With Quote
Old   February 13, 2014, 07:17
Krishna
Thanks Bobi.
I will try to run a simple example and will see if I run into some issues.
Cheers,
Krishna
How to setup a proper "heatFlux" boundary for fireFoam? Jumping OpenFOAM Pre-Processing 0 March 27, 2013 09:27
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
