InterPhaseChangeFoam tutorial problems with OpenFoam222
Old   January 14, 2014, 12:18
Default InterPhaseChangeFoam tutorial problems with OpenFoam222
Rictor is on a distinguished road
Dear Foam users,
i am trying to use the interPhaseChangeFoam solver to simulate condensing water on a wall.
I followed the tutorial(interPhaseChangeFoam tutorial by Martin Andersen) instructions but in the last step something went wrong.
Using the solver an error occurs.
-->FOAM FATAL IO ERROR
keyword pSat is undefined in dictionary ".../constant/transportProperties"
This error occurs only in the latest version OpenFoam 2.2.2. In version 2.1.1 run the modified solver.
Where is the problem?
Rictor is offline   Reply With Quote
Old   February 28, 2014, 11:09
Baris (Heewa)
shipman is on a distinguished road
it says pSat is not defined. So define it as it is done in version 2.1 at dictionary ".../constant/transportProperties" i also used ver 2.2 it works...
shipman is offline   Reply With Quote
Problems on mesh adaptation ervasph SU2 3 October 12, 2013 11:34
in which states and problems we should used correctPhi or ddtPhiCorr ? mechy OpenFOAM 2 September 14, 2013 08:16
Weird problem with engineFoam tutorial chris1980 OpenFOAM Running, Solving & CFD 29 August 28, 2013 06:53
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Problems with channelOodles tutorial alberto OpenFOAM Running, Solving & CFD 0 June 5, 2007 09:08
