InterFOAM Pressure Relaxation
Old   March 4, 2014, 04:56
Default InterFOAM Pressure Relaxation
Za-ck is on a distinguished road
if I have a look into the interFOAM code of OpenFOAM 2.2 I can't see the code for the underrelaxation of p_rgh. Normaly, like in pimpleFOAM for example there is a line "p_rgh.relax()" before the momentum corrector.
Nevertheless, the underrelaxation seems to work, because I get different results if I change the factor for p_rgh.
Can someone please explain me, how the relaxation is implemented in interFOAM.
Best regards,
Za-ck
Za-ck is offline   Reply With Quote
Old   September 4, 2014, 08:59
Sebastian
Googlestuff is on a distinguished road
I would also like to know how to estimate the relaxation factors for the use in interFOAM. Can anyone give a hint how to do that or give a guess for the values?
Regards,
Googlestuff
Googlestuff is offline   Reply With Quote
Old   September 4, 2014, 11:04
Hi Googlestuff,
the underrelaxation values depend on the case and some other solver settings.
If you are using small timesteps you can run the solver in piso-mode. This means that you have only one outerCorrector(simple loop) loop but at least 2-3 corrector loops (piso loops). In this case you do not necessary need underrelaxation.
If you are running the solver in simple (or pimple) mode you only need one corrector loop but more outerCorrector loops. In this case the solution of the continuity equation is just an approximation and you need underrelaxation. Usally one recommended values like 0.3 for p_rgh and 0.7 for U. It is recommended to use values following the equation 1 = p_rghRelaxation + URelaxation to get fast convergency.
I'don't have any rules for the turbulence or the VOF equation.
I hope that answered your question.
Best,
Za-ck
Old   September 4, 2014, 12:06
Sebastian
Yes, thank you very much!
static pressure BC for interFoam kwardle OpenFOAM 2 March 4, 2015 04:29
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 11:59
Pressure reference in cyclic interFoam AlmostSurelyRob OpenFOAM 7 February 16, 2011 09:58
Interfoam (OF 1.7) : pressure evolution, impact, 2D computation kassiotis OpenFOAM 2 December 21, 2010 15:09
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
