Problems with including "cmath"
Old   April 6, 2014, 15:00
Default Problems with including "cmath"
maybee is on a distinguished road
hi,
I am using OpenFOAM with QtCreator. Currently I have to implement some Integralfunctions with several input parameters like:
class IntegralFunctionB
private:
    double x;
    double y;
public:
    IntegralFunctionB(double a, double b)
        x = a;
        y = b;
    double operator()(double d) const
        return pow(y,4)*(6.4/d)*exp(-(4.5*pow(2.0*pow(d,3.0)-pow(x,3.0),2.0))/pow(x,2.0));
I get the error:
/home/USER/SolverNEW/NEW/SourceTermIntegralFunctions/IntegralFunctionB.H:16: error: call of overloaded ‘pow(double&, const double&)’ is ambiguous
candidates are:
/usr/include/i386-linux-gnu/bits/mathcalls.h:155: double pow(double, double)
Therefore I've added the filepath to...
... the Make/options file:
-Iusr/include/i386-linux-gnu/bits
... the include file of the IDE (Qt Creator):
For the include I tried
#include "mathcalls.h"
#include <mathcalls.h>
but when building my project I get the error:
/home/USER/SolverNEW/multiphaseEulerFoamNEW.C:46: error: mathcalls.h:
No such file or directory
Please note also that in "usr/include/i386-linux-gnu/bits" only root has full access, others are just authorised to "access files", but setting the permissions for other to "read and write" does not change the output.
How can I solve this problem since I need to use the "pow(double,double)" method?
EDIT:
If I use Foam:ow(....) the code compiles fine, but I ve only found some kind of Foam:ow(double,double) here:
https://github.com/OpenFOAM/OpenFOAM.../doubleFloat.H
Is this the method called when doing Foam:ow(...) and will it work for Foam:ow(double,double)?
maybee is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
