wmake error own solver
Old   April 10, 2014, 07:10
Default wmake error own solver
MSF
MSF is on a distinguished road
I'm trying to compile my own solver (OpenFoam 1.6) on our cluster and after copying the folder,changing the name of the folder and the .c, editing the options file i typed wmake. First it says that inside Make/linux.../options a delimiter is missing. I fixed this by removing the line break. Then i typed wmake again and got the following error message
Making dependency list for source file myIcoFoam.C
SOURCE=myIcoFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/myIcoFoam.o
In Datei, eingefügt von /usr/include/limits.h:27,
von /opt/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/include-fixed/limits.h:122,
von /opt/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/include-fixed/syslimits.h:7,
von /opt/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/include-fixed/limits.h:11,
von /opt/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../include/c++/4.3.3/climits:48,
von /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/label.H:39,
von /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/labelList.H:36,
von /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Pstream.H:44,
von /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/OPstream.H:36,
von /opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/parRun.H:36,
von /opt/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvCFD.H:4,
von myIcoFoam.C:33:
/usr/include/features.h:324:26: Fehler: bits/predefs.h: Datei oder Verzeichnis nicht gefunden
/usr/include/features.h:357:25: Fehler: sys/cdefs.h: Datei oder Verzeichnis nicht gefunden
/usr/include/features.h:389:23: Fehler: gnu/stubs.h: Datei oder Verzeichnis nicht gefunden
I tried to compile this a home in a VirtualBox and it worked. Any ideas what is missing on the cluster?
Kind regards
Moritz
MSF is offline   Reply With Quote
Old   April 10, 2014, 12:06
Tomislav Maric
tomislav_maric is on a distinguished road
These
header files are stored in '/usr/include' which means that they belong to system packages, they are not related with OpenFOAM installation - well, not directly.
Try and find out the version of the operating system you are using by executing:
cat /etc/issue
then try and search for packages for that operating system that contain those files (here's an example of such problem for Ubuntu). If you have root access to the cluster, install the package, if not, contact your cluster admin and let him know what packages are missing.
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Add a FORTRAN object to wmake compilation directives vitors OpenFOAM Programming & Development 1 April 9, 2014 14:25
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
compliing a new solver with wmake kirankarki OpenFOAM 18 October 26, 2010 17:59
Wmake problem interFoam solver feijooos OpenFOAM Running, Solving & CFD 4 December 8, 2008 11:01
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
