measuring the performance of some fragments of codes
Old   April 23, 2014, 05:32
Default measuring the performance of some fragments of codes
ooo
ooo is on a distinguished road
Hi FOAMers,
I added some lines of code to a solver and would like to measure the performance of each part, e.g pressure solver, momentum solver and so on, Would it be the EXACT way of measuring?
double a = clock::getTime();
THE CODE;
double b = clock::getTime();
elapsed cpu time for that part of code EXACTLY is : (b-a) ?
I expected to get nearly same value, but using the above method,sometimes provides strange results.
e.g for a particular fragment of code, it gives performance of 9%, and sometimes 15% (the simulation is converged)
actually when i print out the value of the scalar/double a or b, it seems that it can be 9 precision number ,so subtraction may lead to some errors due to that range of accuracy
Thanks in advance.
UPDATE : using 'elapsedCpuTime' gave accurate time and solved the problem.
ooo is offline   Reply With Quote
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 09:01
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 15:52
Is it worth it? Jason Bardis Main CFD Forum 47 July 27, 2011 04:52
Comparison of CFD Codes Kerem Main CFD Forum 9 May 9, 2003 04:29
Anyone used Ansys/Flotran - cf. with other codes? S. Langsford Main CFD Forum 3 October 19, 1998 20:51
