how to add a new pointField as sixDoFRigidBodyDisplacement |
May 15, 2014, 03:09 |
Yejun Gong
Rep Power: 18 |
Dear all,
I need to create a new boundary condition for pointDisplacement similar to sixDoFRigidBodyDisplacement. What I have done is just copied the whole directory of sixDoFRigidBodyDisplacement into the same directory, changed the name, and passed the compilation. It is still depend on sixDoFRigidBodyMotion. Then I recompiled the whole OpenFOAM-1.6-ext. But when I run the floatingObject case, it cannot find the new pointField. The error message is as below. Hope got an idea from you! Regards, Yejun Code:
--> FOAM FATAL IO ERROR: Unknown patchField type twoDRigidBodyDisplacement for patch type wall Valid patchField types are : 23 ( zeroGradient processor generic global uncoupledSixDoFRigidBodyDisplacement wedge surfaceDisplacement value sixDoFRigidBodyDisplacement fixedValue slip empty oscillatingFixedValue mixed calculated angularOscillatingDisplacement oscillatingVelocity symmetryPlane oscillatingDisplacement cyclic timeVaryingUniformFixedValue angularOscillatingVelocity surfaceSlipDisplacement ) |
May 15, 2014, 05:53 |
Yejun Gong
Rep Power: 18 |
it works now.
I just move it to the user's folder, then it works. Quite strange. Everything is the same. |
December 5, 2014, 12:08 |
ok
Dear Yejun,
could you post your pointDisplacement file. I'm trying to do the same. I would like to let cylinder oscillates with 2 degrees of freedom. I need your help please. What are the steps? Thanks in advanced and regards. |
April 19, 2020, 16:03 |
#4 | |
Paulo
Rep Power: 8 |
Hey Maimouna, Have you solved your problem? I have the same situation. Thanks. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[PyFoam] and paraview | eelcovv | OpenFOAM Community Contributions | 28 | May 30, 2016 09:23 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
