Pressure field values from the previous iteration?
Old   June 5, 2014, 07:46
Default Pressure field values from the previous iteration?
Petr Furmanek
petr.f. is on a distinguished road
Dear Foamers,
I'd like to damp oscillations in pressure produced as a side-effect of a custom boundary condition. Hence I need values of pressure from the actual as well as the previous iteration. Is there a way how to get them from the body of the boundary condition?
Thanks a lot for response in advance.
petr.f. is offline   Reply With Quote
Old   June 6, 2014, 10:30
Petr Furmanek
OK, this problem is solved - by adding private member to this boundary condition class for storing the pressure value (as I'm using average pressure value end hence not need the whole field)...
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 07:26
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Huge negative pressure after first iteration using rhoPorousSimpleFoam md_lieber OpenFOAM Running, Solving & CFD 4 July 18, 2010 20:45
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Using SIMPLE david Main CFD Forum 5 July 21, 1999 02:38
