February 1, 2019, 09:28 |
Implementation of adjoint equation
Alexis Courtais
Rep Power: 8 |
Hi everyone,
I am trying to implement the following equation within OpenFOAM (Ua is the adjoint velocity) : - Ua+Ua U- ( Ua) U + pa = -2 U I tried the following implementation but I'm not sure it computes the adjoint equation above Code:
volTensorField gradU (fvc::grad(U)); volVectorField adjointTransposeConvection2(gradU.T() & Ua); tmp<fvVectorMatrix> tUaEqn ( fvm::div(-phi, Ua) +fvm::Sp(fvc::div(phi),Ua) + adjointTransposeConvection2 +turbulence->divDevReff(Ua) == fvOptions(Ua) ); fvVectorMatrix& UaEqn = tUaEqn.ref(); UaEqn.relax(); fvOptions.constrain(UaEqn); solve(UaEqn == -fvc::grad(pa)-2*tau*fvc::laplacian(nu,U)); Thanks in advance. Berilmun |
February 1, 2019, 11:02 |
Andrew Somorjai
Rep Power: 12 |
February 3, 2019, 11:18 |
Alexis Courtais
Rep Power: 8 |
February 3, 2019, 14:59 |
#4 | |
Andrew Somorjai
Rep Power: 12 |
template<class BasicTurbulenceModel> Foam::tmp<Foam::fvVectorMatrix> Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff ( volVectorField& U ) const { return ( - fvc::div((this->alpha_*this->rho_*this->nuEff())*dev2(T(fvc::grad(U)))) - fvm::laplacian(this->alpha_*this->rho_*this->nuEff(), U) ); } nuEff() is the effective viscosity. dev2 is line 115 from https://www.openfoam.com/documentati...8C_source.html Just use -fvm::laplacian(nu, Ua). |
February 3, 2019, 16:21 |
#5 | |
Alexis Courtais
Rep Power: 8 |
Do you have a tip to modeling the term ( Ua)U? |
February 4, 2019, 15:33 |
Andrew Somorjai
Rep Power: 12 |
from here Understanding fvm::Sp() What exactly is that term by the way, is Ua the flux? |
Convective term in heat equation for rotating solids | vabishek | OpenFOAM Programming & Development | 8 | June 24, 2020 11:10 |
Current conservation equation implementation | miguelmontenegro | Fluent UDF and Scheme Programming | 0 | May 8, 2018 06:04 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
Diffusion Equation | izardy amiruddin | Main CFD Forum | 2 | July 4, 2002 08:14 |
