Manually entering fvSchemes information into mesh object |
October 6, 2014, 15:43 |
Anirban Jana
Rep Power: 16 |
For a particular application, I have written a code that creates the mesh object using the constructor Code:
fvMesh (const IOobject &io, const Xfer< pointField > &points, const Xfer< faceList > &faces, const Xfer< labelList > &allOwner, const Xfer< labelList > &allNeighbour, const bool syncPar=true) However, the fvSchemes information are absent from the resulting mesh object, i.e., mesh.schemesDict() will return empty braces {}. I expected this, and thought I can afterwards insert this missing information into the mesh object, but I am unable to find the right method to do this. Data members like mesh.ddtSchemes_ etc are private and so cannot be edited later. E.g., Code:
error #308: member "Foam::fvSchemes::ddtSchemes_" (declared at line 57 of "/work/01255/siliu/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvSchemes.H") is inaccessible mesh.ddtSchemes_.add(keyType("ref"),7.0); Code:
error: no instance of overloaded function "Foam::dictionary::add" matches the argument list and object (the object has cv-qualifiers that prevent a match) In file included from icoFoam_iohdf5.C(44): argument types are: (Foam::keyType, double) In file included from icoFoam_iohdf5.C(44): object type is: const Foam::dictionary In file included from icoFoam_iohdf5.C(44): mesh.schemesDict().add(keyType("ref"),7.0); Thanks much in advance Anirban |
Getting access to mesh (fvMesh) via object registry | Chris Lucas | OpenFOAM Programming & Development | 18 | January 15, 2024 02:57 |
[snappyHexMesh] Propeller mesh not smooth | nortanapura | OpenFOAM Meshing & Mesh Conversion | 0 | May 16, 2014 03:26 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
