All cells connected via edge to cell.
Old   August 21, 2014, 17:01
Default All cells connected via edge to cell.
sebastien vilfayeau
sebastien_F1 is on a distinguished road
Hi everyone,
I would like to calculate the average of neighbour cells connected by edge. I already know how to do the average of neighbour cells connected by face:
labelListList neighbour = this->mesh().cellCells();
However, I cannot find those connected by edge.
Let me know if you have any hint.
Best,
Sebastien
sebastien_F1 is offline   Reply With Quote
Old   August 21, 2014, 20:05
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Originally Posted by sebastien_F1 View Post
Hi everyone,
Best,
Sebastien
Hi Sebastien,
You could start by taking a look at /src/OpenFOAM/lnInclude/primitiveMesh.H
There you should be able to spot a lot of useful connectivity information, including the cellCells function which you seem to have already discovered.
With a combination of edgeCells and cellEdges you should be able to assemble a data structure which suits your needs.
I hope that helps!
Cheers,
Kyle
kmooney is offline   Reply With Quote
Old   August 27, 2014, 11:22
sebastien vilfayeau
Hi Kyle,
Thanks for the advice. I have already explored this class. But I was wondering if someone already put all the piece together and do a smart filtering to not count for duplicate cells.
I did it. Here is my piece of code to calculate average with cells connected by edge or points.
/****Calculate an average temperature with neighboor cells****/
avgT_ = dimensionedScalar("b",dimTemperature,0.0);
forAll(T_tilde_.internalField(),celli)
// Construct cellEdges
DynamicList<label> cellStorage;
//labelList neighborEdge = this->mesh().cellEdges()[celli];
labelList neighborEdge = this->mesh().cellPoints()[celli];
cellStorage.clear();
//Do quadratic insertion
forAll(neighborEdge, edgej)
//labelList neighborCell = this->mesh().edgeCells()[neighborEdge[edgej]];
labelList neighborCell = this->mesh().pointCells()[neighborEdge[edgej]];
forAll(neighborCell, cellj)
label ownCellI = neighborCell[cellj];
//Check if not already in storage
forAll(cellStorage, j)
if(cellStorage[j] == ownCellI)
ownCellI = -1;
break;
//if not, add to the storage list
if (ownCellI != -1)
cellStorage.append(ownCellI);
// Calculate the average of cells connected via edge or points
forAll(cellStorage, cellk)
avgT_[celli] += T_tilde_[cellStorage[cellk]];
avgT_[celli] /= cellStorage.size();
//Info << "Cell neighboor = " << cellStorage.size() << endl;
//Info << "Cell = " << celli << endl;
Best
Sebastien
Old   August 27, 2014, 12:27
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Sebastian,
A small word of warning:
Your averaging is based on the number of cells with a uniform weighting. You might want to perform a weighting by cell volumes on non-equidistant meshes.
You can also find the volume in the primitive mesh class, which Kyle pointed to.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
edges, neighboring cell
[snappyHexMesh] Snappy creates strange cells far away from boundary vainilreb OpenFOAM Meshing & Mesh Conversion 3 December 16, 2020 05:11
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 19:18
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
