Sequence diagram wallfuntions
Old   September 22, 2014, 04:03
Default Sequence diagram wallfuntions
Julian Hüttner
juhuettn is on a distinguished road
Hello all,
I am trying to program a new wallfunction which is interacting with the kEpsilon model. Depending on values calculated in my wallfunction, the turbulence model needs to choose between two functions for calculating Epsilon and return it to the wallfunction.
I am looking now for a Sequence Diagram or something similar to understand the correct timeline interaction between the wallfunction and the turbulence model, can anyone help?
Thanks very much,
Julian
juhuettn is offline   Reply With Quote
Old   October 30, 2014, 07:32
Joachim Herb
jherb is on a distinguished road
I am not really sure, but I think it is done this way:
The values for the wall are calculated in the in wall boundary condition, e.g. in nutWallFunctionFvPatchScalarField.C in updateCoeffs(). Then in the turbulence model, e.g. kOmegaSST.C, in correct() this function is somehow called (there is e.g. a call to omega_.boundaryField().updateCoeffs() and the values used for the equations (k and omega).
Hope this helps (and is not much too late).
jherb is offline   Reply With Quote
Question on the sequence of grad(U) components ripperjack OpenFOAM Post-Processing 1 September 18, 2018 12:19
Propagation of errors on the Enthalpy diagram dmaz Main CFD Forum 0 March 13, 2013 03:41
Loading Animation Sequence in FLUENT Produces Blank Screen SeanQuallen FLUENT 0 February 17, 2012 09:56
Software to build avi from a sequence of images hsieh OpenFOAM Post-Processing 2 January 18, 2008 22:12
