How to access to field point data
Like Tree1Likes
  • 1 Post By Arnoldinho
Old   August 9, 2012, 10:40
Default How to access to field point data
Jian Zhong
zxj160 is on a distinguished road
Dear foamers,
I can have access to coordinate of point by:
mesh.points(), and field cell data by U.mesh().C()[].
But now my problem is that how to access and change the corresponding field point data if I choose some interested coordinate?
Many thanks,
Jian
zxj160 is offline   Reply With Quote
Old   August 10, 2012, 14:25
Arne Stahlmann
Arnoldinho is on a distinguished road
The values are always stored "in the cells" or at the boundaries, i.e. there is no value assignment for points. These only give the coordinates of the cells.
If you are interested in manipulating the (cell) values at a location x,y,z of interest, you could e.g. have a look at mesh.findCell(), http://www.cfd-online.com/Forums/ope...ordinates.html, which gives you the position in the field (cell index) you want to manipulate.
Greetings,
Arne
Arnoldinho is offline   Reply With Quote
Old   August 11, 2012, 06:35
Jian Zhong
Greetings,
Arne
Dear Arne,
Many thanks. After I have changed the field data of some cells (first layer of inlet as zero), the case can not run in parallel. Do you know how to solve the problem?
My best regards,
Jian
Old   August 11, 2012, 07:11
Arne Stahlmann
You did not give the entire error you get from your run, so I'm not sure what's the problem.
But you have to keep in mind that if running in parallel, every single processor builds up its own mesh, i.e. face and point labels refer to the single processor meshes and are different from the global mesh labels!
Arne
Old   August 11, 2012, 16:47
Jian Zhong
Arne
Dear Arne,
Actually, I first select the first layer cell IDs near the inlet and outlet after searching the whole cells. Then I modified the corresponding cell values. It can run directly in one cpu, but can not run in parallel. Do you have any code or documents about parallel running?
My best regards,
Jian
Old   August 14, 2012, 03:32
Arne Stahlmann
Hi Jian,
I am still not sure what the problem is. Did you check whether you modified the right cells, e.g. by having a look at the specific processorX folders in ParaView and giving the cells e.g. large numbers?
I am afraid I have no further documents about parallel coding, but my field/cell modifications so far work in parallel with no problem.
One hint: if you are just modifying the boundary-next cells, you could use
const label patchi = mesh.boundaryMesh().findPatchID("inlet");
U.boundaryField()[patchi] == whatever you want
which saves you the time-consuming searching for single cells.
Greetings,
Arne
manijm likes this.
Old   May 21, 2015, 05:35
Fei Fan
Fanfei is on a distinguished road
Hi Jian,
Greetings,
Arne
Hi Arnoldinho:
I'm so sorry to trobule you and dig that old topic. I have a problem to access the points coorinadte of the assign face. for example i want to get the nodes coordinate of mesh.BoundaryField()[patchID][I], how i can do that? Thank you.
Greeting
Fan Fei
Fanfei is offline   Reply With Quote
problem in toposet Ahmed Khattab OpenFOAM Pre-Processing 27 March 3, 2023 21:12
[ANSYS Meshing] Importing Cylinders by Point Data Input with Radii EphemeralMemory ANSYS Meshing & Geometry 2 May 31, 2012 13:34
matching variable data with grid point data anfho OpenFOAM Programming & Development 0 May 6, 2011 15:28
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to access acceleration of steady Euler field? winnie FLUENT 0 May 2, 2003 22:53
