Problem creating user defined Boundary conditions
Prev Previous Post   Next Post Next
Old   October 27, 2014, 18:40
Default Problem creating user defined Boundary conditions
Fredrik Eikeland Fossan
fredf is on a distinguished road
Helo. I´m trying to modify an exciting boundary condition, but get an error message when trying to visualize it in paraview. I copied all of the files in the existing oscillatingFixedValue into a folder called myBCs in my WM_PROJECT_USER_DIR folder. i renamed all the files, and did my changes in the corresponding .C file. Then made Make/files and Make/options files. Make/files consist of:
myFixedValueFvPatchFields.C
LIB = $(FOAM_USER_LIBBIN)/libmyBCs
Make/options consist of:
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS = \
-lfiniteVolume
then I run the "wake libso" command from the terminal "standing" in myBCs folder. Compiling doesn´t raise any error message.
then i add this boundary condition to my case, and also add the following lines in the controlDict.C file:
libs ("libmyBCs.so");
My case uses icoFoam, and running this doesn´t raise any error message either, but when I try to visualize the results in paraview, it paraFoam exits and I get an error-message reading:
" FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : /home/fredrik/OpenFOAM/fredrik-2.3.0/platforms/linux64GccDPOpt/lib/libmyBCs.so: undefined symbol: _ZTIN4Foam5token8compoundE
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libmyBCs.so"
Does anybody know what might be wrong?
fredf is offline   Reply With Quote
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Units problem and boundary conditions with potentialFoam Calu OpenFOAM Running, Solving & CFD 0 February 14, 2014 13:31
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
