May 15, 2015, 01:49
Error in running case in chtMultiRegionFoam
baran
Greeting all!!!
I want to use the chtMultiRegionFoam for a geometry of air surrounding with solid.
When i was trying to run this case I got the following error .....
Create time
Create fluid mesh for region fluid_air for time = 0
Create solid mesh for region solid_insu for time = 0
*** Reading fluid mesh thermophysical properties for region fluid_air
Adding to thermoFluid
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Adding to rhoFluid
Adding to kappaFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85034;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
Prt 1;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
c1 10;
Adding to ghFluid
Adding to ghfFluid
Selecting radiationModel viewFactor
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel constantScatter
Total number of clusters : 115
Insert elements in the matrix...
Smoothing the matrix...
Adding to KFluid
Adding to dpdtFluid
*** Reading solid mesh thermophysical properties for region solid_insu
Adding to thermos
Constructed constSolidThermo with
rho : rho [1 -3 0 0 0 0 0] 8000
Cp : Cp [0 2 -2 -1 0 0 0] 450
K : K [1 1 -3 -1 0 0 0] 80
Hf : Hf [0 2 -2 0 0 0 0] 0
emissivity : emissivity [0 0 0 0 0 0 0] 0.7
kappa : kappa [0 -1 0 0 0 0 0] 0
sigmaS : sigmaS [0 -1 0 0 0 0 0] 0
Region: fluid_air Courant Number mean: 1.61574e-05 max: 8e-05
Region: solid_insu Diffusion Number mean: 4.7133365e-07 max: 1.7777782e-06
Time = 0.0001
Solving for fluid region fluid_air
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
at sigaction.c:0
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam:perator/(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7 Foam::fvMatrix<double>::solve() in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/chtMultiRegionFoam"
#9 __libc_start_main in "/lib64/libc.so.6"
Can anyone kindly mention exactly where I have done the mistake??
Thanks in advance
regards,
baran
