February 15, 2012, 05:16 |
Explanation of "solve"-function
Hello out there in the big OpenFOAM-world.
Is there anybody who can really explain to me the solve-function? If I look at Code:
->solve(psiCmpt, sourceCmpt, cmpt); - But where is that solver really defined? - Where can i find the actual definition of the function "solve()"? And if there is somebody really knowing about that solve-function: - Is there a way to call that solve() for a specific cell only? I am kind of lost with the C++ stuff or at least inside the structure of OpenFOAM, so any help is welcome! |
February 1, 2015, 00:41 |
Chenguang Zhang
Rep Power: 13 |
Hi Bernhard, did you find any information regarding the functionality of the solve() function? Thanks.
February 1, 2015, 23:30 |
Alberto Passalacqua
Rep Power: 36 |
The solve function you are looking at is a virtual function ( http://foam.sourceforge.net/docs/cpp/a02380.html ) which is redefined for each solver (diagonalSolver, GAMGSolver, ...).
If you want to solve a linear system directly in a cell or a limited number of cells, you probably want to follow a simpler way. You can, for example, use a scalarSquareMatrix and use LU decomposition on it (OF can do it).
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. Last edited by alberto; February 1, 2015 at 23:47. Reason: Corrected answer |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
