How would you dynamically allocate higher order arrays in OF?
Prev Previous Post   Next Post Next
Old   February 2, 2015, 09:50
Default How would you dynamically allocate higher order arrays in OF?
Rudolf Hellmuth
rudolf.hellmuth is on a distinguished road
Hallo,
I need to allocate higher order arrays in OF, like 3D, 4D large matrices. I couldn't find any native OF class that do that. For 1D arrays I am using PtrList. In the case of 3rd order array, is it possible to use?:
PtrList<PtrList<PtrList<scalar>>>> array;
array.setSize[sizeX];
forAll(array, i)
    array[i].setSize[sizeY];
    forAll(array[i], j)
        array[i][j].setSize[sizeZ];
Is this safe in terms of memory leak? The member function PtrList::set would act funny, wouldn't it?
Or should I ratter allocate in a standard way?
scalar*** array;
array = new scalar**[sizeX];
for(int i = 0; i < sizeX; ++i)
     array[i] = new scalar*[sizeY];
     for(int j = 0; j < sizeY; ++j)
          array[i][j] = new scalar[sizeZ];
Then deallocate the array within delete loop in the class destructor.
How would you rather do that?
Best regards,
Rudolf
rudolf.hellmuth is offline   Reply With Quote
higher order discretisation scheme Simon Smokes Main CFD Forum 2 August 23, 2014 07:19
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 16:31
Higher Order FV Schemes for unstructured meshes Apurva Shukla Main CFD Forum 4 December 15, 2000 09:17
Gradient Estimation for Higher Order Schemes jianxia Main CFD Forum 0 June 6, 2000 19:40
Higher order FVM Sergey Smirnov Main CFD Forum 10 April 15, 2000 01:49
