Error arise after alpha smooth modification in interfaceProperties::calculateK
Old   September 2, 2014, 11:47
Default Error arise after alpha smooth modification in interfaceProperties::calculateK
red.yxg is on a distinguished road
Dear All:
Now I am using interFoam to simulate 2-phase flow. I smoothed the alpha by some changes in interfaceProperties.c in Foam::interfaceProperties::calculateK() according to Laplacian filter(3.51) in Onno Ubbink's thesis. No error arise in recompilation of interfaceProperties.c and interFoam.c . But when I call interFoam calculating a case, error arised:
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library.
So I just go back to the interfaceProperties.c and change the code line by line to check what caused this problem:
void Foam::interfaceProperties::calculateK()
    const fvMesh& mesh = alpha1_.mesh();
    const surfaceVectorField& Sf = mesh.Sf();
    const volScalarField& volSmoothAlpha0=alpha1_;  // added by me
    const volScalarField& surfaceSumArea=fvc::surfaceSum(mesh.magSf()); // added by me
    const surfaceScalarField& surfaceSmoothAlpha0=Foam::linearInterpolate(volSmoothAlpha0); // added by me
    const surfaceScalarField& surfaceAreatimesAlpha0=surfaceSmoothAlpha0*mesh.magSf();  // added by me
    const volScalarField& surfaceSumAreatimesAlpha0=fvc::surfaceSum(surfaceAreatimesAlpha0); // added by me
    const volScalarField& volSmoothAlpha1=surfaceSumAreatimesAlpha0/surfaceSumArea; // added by me, this one cause the problem. !!!
The last line caused the error. I am new to OpenFoam. Maybe this is a simple question. So anyone has the hint ? Thanks !
Yin
red.yxg is offline   Reply With Quote
Old   September 3, 2014, 04:30
David Gaden
marupio is on a distinguished road
You are misusing references (the ampersand '&').
1. volScalarField theActualObject;
2. volScalarField& referenceToObject = objectToWhichItRefers;
1 is an actual instance of an object that takes up real memory.
2 is a reference to another object stored elsewhere, and notice it *must* be initialized by the object it points to right away.
Only use the '&' if you know the object exists already somewhere else. Hope that helps.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   September 3, 2014, 04:40
Hi, David:
Thank you for your reply. Yeah, you are right. I am just too new to C++ and OpenFOAM. I will check whether I can manage it.
Cheers,
Yin
Old   March 24, 2015, 17:02
suchi89 is on a distinguished road
Have you been able to resolve this?
Also, I am trying to implement the same smoother in alphaEqnSubCycle.C instead of at interfaceProperties.C
Was there a specific reason why the implementation is at interfaceProperties.C and not after calculating alpha at alphaEqnSubCycle.C?\
Thanks,
suchi89 is offline   Reply With Quote
Old   March 25, 2015, 08:50
Yes, later I found smoothing alpha has little influence on my result. So I just quit.
We only need the smoothed alpha for surface tension calculation, so I directly modify in interfaceproperties.C, I think this is more convenient. But I am not sure.
Yin
Old   March 7, 2016, 11:46
mheinz is on a distinguished road
Originally Posted by red.yxg View Post
Yin
I would add that smoothing the alpha field would likely be counterproductive because in general one wants the interface to be sharp. The calculation of the curvature on the other hand is quite inaccurate for a sharp alpha field.
So it seems convenient to use a smoothed alpha field only for the calculation of interface properties.
mheinz is offline   Reply With Quote
extend library, smooth alpha
TwoPhaseEulerFoam and Boundary conditions raagh77 OpenFOAM Running, Solving & CFD 99 February 6, 2018 18:31
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
bubbleFoam tutorial case with turbulence setzberg OpenFOAM Running, Solving & CFD 6 October 15, 2015 13:29
setfields for alpha belkadi OpenFOAM Programming & Development 7 November 25, 2014 11:53
Determining alpha and beta for porous baffle Liaqat Khan Siemens 1 October 27, 2000 04:44
