attempted to assign to a const reference to constant object of type
Like Tree4Likes
  • 1 Post By gaza
  • 3 Post By anydimenx
Old   June 15, 2015, 13:08
Default attempted to assign to a const reference to constant object of type
Przemek
gaza is on a distinguished road
Hi Foamers,
I'm stuck and I need your help wuth error as in the title of this post.
My piece of code is
volScalarField A( T );
volScalarField B( T );
return Pair<tmp<volScalarField> >
A,
B
T is also volScalarField defined in the createFields.H
Can you tell me why "attempted to assign to a const reference to constant object of type" error arise? I find out that the error arises in
the constructor of Pair, but I don't understand why? Here is the code from Pair.H
//- Construct from components 66 inline Pair(const Type& f, const Type& s)
67 {
68 first() = f;
69 second() = s;
70 }
//- Return first 88 inline const Type& first() const
89 {
90 return this->operator[](0);
91 }
92
93 //- Return first
94 inline Type& first()
95 {
96 return this->operator[](0);
97 }
98
99 //- Return second
100 inline const Type& second() const
101 {
102 return this->operator[](1);
103 }
104
105 //- Return second
106 inline Type& second()
107 {
108 return this->operator[](1);
109 }
and operator[]() from FixedList.H
242 inline T& Foam::FixedList<T, Size>:perator[](const label i) 243 {
244 # ifdef FULLDEBUG
245 checkIndex(i);
246 # endif
247 return v_[i];
248 }
249
250
251 // const element access
252 template<class T, unsigned Size>
253 inline const T& Foam::FixedList<T, Size>:perator[](const label i) const
254 {
255 # ifdef FULLDEBUG
256 checkIndex(i);
257 # endif
258 return v_[i];
259 }
Any help is really appreciated
best regards
pblasiak
gaza is offline   Reply With Quote
Old   June 16, 2015, 04:41
Przemek
Can anybody help me?
best regards
pblasiak
Old   June 16, 2015, 10:51
Przemek
I solved my problem by implementation:
A*scalar(1),
B*scalar(1)
I do not know why now it works?
This solution is not good. If anybody know how to fix it please share your knowledge.
I don't think so it is a bug in tmp class. Rather I do something wrong. But why can't I
return Pair of volScalarField?? It is strange.
best regards
pblasiak
Old   June 17, 2015, 02:53
Przemek
This is strange for me that if I want return
Pair<tmp<volScalarField> >(A,B);
A and B have to be expressions. For example
Pair<tmp<volScalarField> >(A*scalar(1),B*scalar(1));
works and Pair<tmp<volScalarField> >(A,B); does not.
Does anybody know why it is?
ali moeni likes this.
best regards
pblasiak
Old   September 23, 2015, 05:17
Default I meet the same problem.
Li Jinlong
anydimenx is on a distinguished road
I meet the same problem, my solution is :
Pair<tmp<volScalarField> >(1.0 * A, 1.0 * B);
It is like the solution above, but I don't know why. What if the type of A, B doesn't support the operator *? How to construct the object of type Pair?
anydimenx is offline   Reply With Quote
Old   September 23, 2015, 06:20
Przemek
Hi anydimenx,
Yes I don't know what then.
But I think now I know the universal solution but I didn't check it.
Probably you have to use construction with "new" statement.
Something like that:
new Pair<volScalarField>
A, B
but you have to check it because syntax could be wrong.
best regards
pblasiak
Old   September 24, 2015, 10:13
Default The way to construct the object of Pair<T>
Li Jinlong
Hi, gaza, thank you for your ideas.
I have tried your solution, but it cannot pass the compiling. However, your idea enlightens me. It seems that I've found the universal solution:
tmp<volScalarField>(A),
tmp<volScalarField>(B)
assuming A and B are objects of type volScalarField.
Pair<Type> is a class template, which has a constructor:
So the arguments of that constructor should be of type tmp<volScalarField>
tmp<T> is a class template, which has a constructor:
tmp(const T&)
tmp<volScalarField>(A) creates an unnamed smart pointer of the instantiated class tmp<volScalarField>
And I search the declaration of operator* through the Doxygen:
tmp<GeometricField<Type, PatchField, GeoMesh> > Foam:perator*
const dimensioned<scalar>& dt1,
const GeometricField<Type, PatchField, GeoMesh>& df2
const GeometricField<Type, PatchField, GeoMesh>& df1
const dimensioned<scalar>& dt2,
const scalar& dt1,
const scalar& dt2,
So this is why A*scalar(1) and 1.0*A satisfy the type of the parameters of the class Pair constructor, but A cannot. The result of the multiplication is of type tmp<volScalarField>.
Old   September 24, 2015, 10:37
Przemek
Hi anydimenx,
Thank's a lot for your solution and explanation
best regards
pblasiak
Old   September 25, 2015, 03:07
Li Jinlong
You are welcome, this discussion really helps me a lot, I enjoy it. Thank you for your inspiring and timely reply.
Best wishes.
Old   November 22, 2015, 06:00
Przemek
Originally Posted by gaza View Post
Hi Foamers,
My piece of code is
A,
B
67 {
68 first() = f;
69 second() = s;
70 }
89 {
91 }
92
93 //- Return first
95 {
97 }
98
101 {
103 }
104
107 {
109 }
245 checkIndex(i);
246 # endif
247 return v_[i];
248 }
249
250
254 {
256 checkIndex(i);
257 # endif
258 return v_[i];
259 }
this generally is solved in OF via such construction for instance (solver thermoFoam):
75 talphaEff = tmp<volScalarField>
76 (
77 new volScalarField
78 (
79 IOobject
80 (
81 "alphaEff",
82 runTime.timeName(),
83 mesh,
84 IOobject::NO_READ,
85 IOobject::NO_WRITE
86 ),
87 mesh,
88 dimensionedScalar("0", dimMass/dimLength/dimTime, 0.0)
89 )
90 );
best regards
pblasiak
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 04:14
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
problem in making a new solver!!! adambarfi OpenFOAM Running, Solving & CFD 18 September 29, 2012 11:56
