Accessing thermoPhysical Property Functions - e.g. mixture_.rho(scalar p, scalar T) |
June 23, 2015, 00:32 |
Will Logie
Rep Power: 15 |
I am looking to post-process buoyantPimpleFoam (perfectGas rho, Sutherland mu, JANAF Cp) results and extract some heat transfer characteristics for a wall [patchi] based on the Rayleigh Number:
Ra.boundaryField()[patchi] = ( gravity * betaFilm.value() / ( muFilm.value() / rhoFilm.value() * alphaFilm.value() ) ) * (T.boundaryField()[patchi] - T_ref.value()) * pow(L.value(), 3); Has anyone done this before or can give me some tips; for example, how best to access the member function: Code:
template<class Specie> inline Foam::scalar Foam::perfectGas<Specie>::rho(scalar p, scalar T) const { return p/(this->R()*T); } My awareness of C++ is insufficient. Thank you, Will. |
June 23, 2015, 05:35 |
Rep Power: 18 |
You need to get access to the thermo object which is used in the solver.
In the solver this is very simple, it's usually stored in a variable called thermo or something similar. Read your solver code for this. In a different program you need to instantiate it the same way as it's done in the solver first. |
June 23, 2015, 23:38 |
Will Logie
Rep Power: 15 |
I'm aware that I can access any [celli] within the simulated thermo variable field which in turn is calculated from the pressure and temperature of that particular cell.
But what I am asking is how does one "calculate" one's own viscosity or density given some "reference" or desired pressure and temperature? For example if I know my film temperature to be 467K at atmospheric pressure, I could calculated film values for density, viscosity and specific heat by way of the respective member functions - I imagine to look like rhoFilm = perfectGas.rho(1e5, 467) Are you implying I could use thermo.rho() in this way, and if so how? |
janaf, memberfunctions, perfectgas, sutherland |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
dieselFoam problem!! trying to introduce a new heat transfer model | vivek070176 | OpenFOAM Programming & Development | 10 | December 23, 2014 23:48 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
accessing thermophysical properties on a lower level | romant | OpenFOAM Programming & Development | 4 | October 28, 2013 08:25 |
