April 16, 2011, 12:15 |
rhoPimpleFoam algorithm
#1 | ||
Perry L. Johnson
Rep Power: 15 |
I am working in OF v1.7.1 and have a couple quick questions regarding the implementation of the compressible PISO-SIMPLE algorithm:
1) On line 00095 of the rhoPimpleFoam/pEqn.H code: Why is the if statement commented out? Should the relaxation of pressure really be allowed in the final outer iteration? Quote:
April 18, 2011, 02:57 |
Christian Lucas
Rep Power: 17 |
you are correct, there should be no relaxation in the last iteration because otherwise you get a continuity error (which is very large if you look at the tutorial case). I'm not sure about the energy equation but would be interested in your result. Regards, Christian |
April 18, 2011, 19:22 |
#3 | ||
Alberto Passalacqua
Rep Power: 36 |
However this aspect might influence convergence rate, but it should not affect the results. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
April 20, 2011, 09:40 |
Perry L. Johnson
Rep Power: 15 |
Alberto and Christian,
Thank you for entertaining my curiosities. I will let you know anything I find through experimentation, though it seems as if Alberto does not expect much difference on either point. For the interested foamer stumbling across this thread, I suggest reviewing the following thread for a more involved discussion of relaxation http://www.cfd-online.com/Forums/ope...ime-steps.html Regards, Perry |
April 20, 2011, 21:56 |
#5 | |
Alberto Passalacqua
Rep Power: 36 |
Yes, I do not expect any difference on the solution.
Best,
July 27, 2015, 10:16 |
#6 | |
Christa
Rep Power: 15 |
this commented-out IF statement has been removed from OF v.2.4, as can be seen here: https://github.com/OpenFOAM/OpenFOAM...oam/pEqn.H#L92 I am getting massive timestep continuity errors and no pressure convergence for what should be a very straightforward problem of orthogonal mesh and subsonic gas flow. After searching a lot in this forum (and it is quite hard to get the keywords right!) I think that if I don't relax the pressure in the last outer iteration my solution may converge. Has anyone tried to do this in newer versions of OF? Anyone know why the commented out section was removed? Can you please guide me to where OF explains changes from one version to the next? Thanks, Christa |
About Poisson equation's B.C. in SMAC algorithm | snakejoe | Main CFD Forum | 0 | April 7, 2009 05:58 |
VOF methods and the Simplre algorithm | Jeff Yanke | Main CFD Forum | 6 | August 25, 2008 00:32 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | Main CFD Forum | 0 | April 18, 2007 03:48 |
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm | Yan Kai | FLUENT | 0 | April 13, 2007 23:17 |
mach-uniform algorithm for LES/DNS | ilyas | Main CFD Forum | 0 | February 22, 2007 10:53 |
