Compile error with a solver using electric potential method from an article
Old   November 30, 2015, 07:01
Default Compile error with a solver using electric potential method from an article
Jun
mykkujinu2201 is on a distinguished road
HI, guys.
I need some help about compiling solver at OpenFoam.
Actually, I'm new to OpenFoam.
I've started to use it for my final project; I have to solve high Hartmann mhd duct flow.
I was using Fluent but it didn't work well.
Anyway I'm compiling solver using electric potential method.
I've found some article about it and it contained source code for it.
I 'copied' whole source code and tried to compile the solver but it doesn't work.
The error is as below.
aking dependency list for source file EpotFoam.C
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude   -fPIC -c EpotFoam.C -o Make/linux64GccDPInt32Opt/EpotFoam.o
In file included from EpotFoam.C:39:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:27:1: error: expected initializer before numeric constant
 50
createFields.H:75:32: error: ‘sigma’ was not declared in this scope
 dimensionedScalar DB = 1.0/(mu*sigma);
createFields.H:75:32: note: suggested alternative:
In file included from /opt/openfoam30/src/OpenFOAM/lnInclude/constants.H:47:0,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:18,
                 from EpotFoam.C:31:
/opt/openfoam30/src/OpenFOAM/lnInclude/physicoChemicalConstants.H:58:36: note:   ‘Foam::constant::physicoChemical::sigma’
     extern const dimensionedScalar sigma;
EpotFoam.C:65:23: error: ‘nCorr’ was not declared in this scope
 for (int corr=0; corr<nCorr; corr++)
EpotFoam.C:69:43: error: ‘ddtPhiCorr’ is not a member of ‘Foam::fvc’
 phi = (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rUA, U, phi);
EpotFoam.C:71:30: error: ‘nNonOrthCorr’ was not declared in this scope
 for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
EpotFoam.C:94:28: error: no matching function for call to ‘laplacian(Foam::scalar&, Foam::volScalarField&)’
 fvm::laplacian(consist,PotE) == consist * fvc::div(psiub)
EpotFoam.C:94:28: note: candidates are:
In file included from /opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.H:188:0,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvm.H:46,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:10,
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:45:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:45:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   mismatched types ‘const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>’ and ‘Foam::scalar {aka double}’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:70:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:70:1: note:   template argument deduction/substitution failed:
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:99:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::zero&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:99:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   cannot convert ‘consist’ (type ‘Foam::scalar {aka double}’) to type ‘const Foam::zero&’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:115:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::zero&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:115:1: note:   template argument deduction/substitution failed:
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:130:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::one&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:130:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   cannot convert ‘consist’ (type ‘Foam::scalar {aka double}’) to type ‘const Foam::one&’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:143:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::one&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:143:1: note:   template argument deduction/substitution failed:
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:155:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:155:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   mismatched types ‘const Foam::dimensioned<Type2>’ and ‘Foam::scalar {aka double}’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:181:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:181:1: note:   template argument deduction/substitution failed:
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:208:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:208:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   mismatched types ‘const Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh>’ and ‘Foam::scalar {aka double}’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:240:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:240:1: note:   template argument deduction/substitution failed:
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:225:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:225:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   mismatched types ‘const Foam::tmp<Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh> >’ and ‘Foam::scalar {aka double}’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:257:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:257:1: note:   template argument deduction/substitution failed:
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:273:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:273:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   mismatched types ‘const Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh>’ and ‘Foam::scalar {aka double}’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:290:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:290:1: note:   template argument deduction/substitution failed:
EpotFoam.C:94:28: note:   mismatched types ‘const Foam::tmp<Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh> >’ and ‘Foam::scalar {aka double}’
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:305:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:305:1: note:   template argument deduction/substitution failed:
                 from EpotFoam.C:31:
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:322:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
 laplacian
/opt/openfoam30/src/finiteVolume/lnInclude/fvmLaplacian.C:322:1: note:   template argument deduction/substitution failed:
make: *** [Make/linux64GccDPInt32Opt/EpotFoam.o] Error 1
I can't understand why it fails and what is wrong.
I really need to solve this problem.
Does anyone help me?
mykkujinu2201 is offline   Reply With Quote
Old   December 1, 2015, 04:05
Agustín Villa
agustinvo is on a distinguished road
it seems you have not defined sigma in your createFields file. Could you upload it?
agustinvo is offline   Reply With Quote
Old   December 1, 2015, 13:19
Smile
Hesam
rapierrz is on a distinguished road
Hello Jun,
I work with mhdFoam and it properly work,what do you need to calculate?
if you want to simulate flow in a duct you don't need any change.
rapierrz is offline   Reply With Quote
Old   December 7, 2015, 11:01
Default Modifed MHDFoam compiling error
Jun
Hello.
I'm keep trying to solve MHD Duct Flow with electric potential mehtod.
I tried to modify simplefoam and it actually works. For turbulence, there is no problem at all but for laminar, it does not converge at high hartman number.
So, I keep searching codes on the internet and I found one.
Unfortunately, it does not show everything. I couldn't figure out which application was modified though it resembled mhdFoam. So, I modified mhdFoam following the code.
That is deetached.
#include "fvCFD.H"
#include "pisoControl.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    pisoControl piso(mesh);
    pisoControl bpiso(mesh, "BPISO");
    #include "createFields.H"
    #include "initContinuityErrs.H"
    Info<< nl << "Starting time loop" << endl;
    while (runTime.loop())
    Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "CourantNo.H"
        volVectorField UcrosB= U ^ B;
        volVectorField j=-sigma*fvc::grad(PotE) + sigma*UcrosB;
        volVectorField jcrosB = j ^ B;
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
          - (jcrosB/rho)
          - fvm::laplacian(nu,U)
            if (piso.momentumPredictor())
                solve(UEqn == -fvc::grad(p));
            // --- PISO loop
            while (piso.correct())
                volScalarField rAU(1.0/UEqn.A());
                surfaceScalarField rAUf("rAUf", fvc::interpolate(rAU));
                volVectorField HbyA("HbyA", U);
                HbyA = rAU*UEqn.H();
                surfaceScalarField phiHbyA
                    "phiHbyA",
                    (fvc::interpolate(HbyA) & mesh.Sf())
                  + rAUf*fvc::ddtCorr(U, phi)
                while (piso.correctNonOrthogonal())
                    fvScalarMatrix pEqn
                        fvm::laplacian(rAUf, p) == fvc::div(phiHbyA)
                    pEqn.setReference(pRefCell, pRefValue);
                    pEqn.solve(mesh.solver(p.select(piso.finalInnerIter())));
                    if (piso.finalNonOrthogonalIter())
                        phi = phiHbyA - pEqn.flux();
                #include "continuityErrs.H"
                U = HbyA - rAU*fvc::grad(p);
                U.correctBoundaryConditions();
        // --- B-PISO loop
        while (bpiso.correct())
            fvVectorMatrix BEqn
                fvm::laplacian(PotE) == fvc::div(UcrosB)
            BEqn.solve();
            #include "magneticFieldErr.H"
        runTime.write();
    Info<< "End\n" << endl;
    return 0;
But it had errors.
Making dependency list for source file EpisoFoam.C
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude   -fPIC -c EpisoFoam.C -o Make/linux64GccDPInt32Opt/EpisoFoam.o
EpisoFoam.C: In function ‘int main(int, char**)’:
EpisoFoam.C:148:13: error: no matching function for call to ‘Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::tmp<Foam::fvMatrix<double> >)’
EpisoFoam.C:148:13: note: candidates are:
In file included from /opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.H:1058:0,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.C:29,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.H:337,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.H:199,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvc.H:44,
                 from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from EpisoFoam.C:51:
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = Foam::Vector<double>]
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note:   candidate expects 2 arguments, 1 provided
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Vector<double>]
 Foam::fvMatrix<Type>::fvMatrix(const tmp<fvMatrix<Type> >& tfvm)
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note:   no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >&’
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = Foam::Vector<double>]
 Foam::fvMatrix<Type>::fvMatrix(const fvMatrix<Type>& fvm)
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note:   no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<double> >’ to ‘const Foam::fvMatrix<Foam::Vector<double> >&’
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = Foam::Vector<double>]
/opt/openfoam30/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note:   candidate expects 2 arguments, 1 provided
Is anyone who can help me?
Old   December 8, 2015, 14:42
Smile
Hesam
I think it was operator precedence problem,
the solution is to use the (U ^ B) instead of U ^ B
Old   December 22, 2015, 05:45
Tomislav Maric
tomislav_maric is on a distinguished road
Originally Posted by mykkujinu2201 View Post
HI, guys.
I need some help about compiling solver at OpenFoam....
You should get used to reading the compiler errors carefully. The first error is the most relevant one.
createFields.H: In function ‘int main(int, char**)’: createFields.H:27:1: error: expected initializer before numeric constant  50
Check the type declaration for the variable of value 50 in createFields.H on line 27. You should post the file that is mentioned in the compiler error in the question you are asking, or prepare a github/bitbucket repo with your code - it makes it much, much easier to help you...
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Old   March 18, 2016, 05:25
Question
RomainBou is on a distinguished road
Did you solve your problem ?
I might have to use your code to solve my case
I will maybe creat a new forum thread, but here is my question :
Can anybody confirm that using only the mhdFoam solver you cannot set up an initial Electrical potential field??
So the only solution is to make your own solver, like your are trying to do?
correct?
My project is to determine the velocity field of a fluid inside a cylinder, given a certain magnetic field and a electric potential field. How can I do that with openfoam ?
Thanks
RomainBou is offline   Reply With Quote
Old   March 29, 2016, 02:37
Krish
krishnan_me is on a distinguished road
Hi, I am trying to create solver for electromagnetic problems. When I created the solver and tried to compile it I received errors. Herewith this post I am posting the result that was generated after "wmake" command.
"g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c rodFoam.C -o Make/linux64GccDPInt32Opt/rodFoam.o
rodFoam.C: In function ‘int main(int, char**)’:
rodFoam.C:41:28: error: ‘sigma’ was not declared in this scope
solve ( fvm::laplacian(sigma, ElPot) );
rodFoam.C:41:28: note: suggested alternative:
from rodFoam.C:31:
/opt/openfoam30/src/OpenFOAM/lnInclude/physicoChemicalConstants.H:58:36: note: ‘Foam::constant:hysicoChemical::sigma’
rodFoam.C:41:35: error: ‘ElPot’ was not declared in this scope
rodFoam.C:42:28: error: ‘A’ was not declared in this scope
solve ( fvm::laplacian(A)==sigma*muMag*(fvc::grad(ElPot)) );
rodFoam.C:42:38: error: ‘muMag’ was not declared in this scope
rodFoam.C:44:5: error: ‘B’ was not declared in this scope
B = fvc::curl(A);
rodFoam.C:45:5: error: ‘Je’ was not declared in this scope
Je = -sigma*(fvc::grad(ElPot));
make: *** [Make/linux64GccDPInt32Opt/rodFoam.o] Error 1"
I have declared all the parameters in createFields.H file. Any help in this issue is much appreciated.
krishnan_me is offline   Reply With Quote
Old   March 30, 2016, 00:09
Krish
I solved it. Thanks.
Old   April 7, 2016, 11:27
Question
Hi krishnan_me,
I am running into the same kind of compiling error right now, could you tell how you solved this problem please ?
Any help will be appreciated
Thanks
Old   April 7, 2016, 21:39
Krish
Hi RomainBou,
First add "#include "createMesh.H" #In the OpenFOAM installation
#include "createFields.H"" after "createTime.H". Then add "XE_INC = \
-I$(LIB_SRC)/meshTools/lnInclude " in options file under makefolder. Now run wmake command. It solved my errors.
While executing your solver, You have to create a file called "setfielddict" in the system folder and initialise the regions. then after blockMesh command you have to run setFields command.
Cannot compile new solver (interFoam with Temperature) MdoNascimento OpenFOAM Programming & Development 2 June 29, 2015 14:31
2D Unsteady Potential Flow Solver A.S. Main CFD Forum 2 November 16, 2005 03:38
free surface potential method paolo Main CFD Forum 0 September 19, 2004 13:29
Free 2D Axisymmetric Potential Flow Solver for Matlab? Jonas Larsson Main CFD Forum 0 August 13, 2003 09:13
Laplace or Stokes equations solver by Boundary Elements Method Lemonnier Main CFD Forum 3 December 28, 1999 13:48
