Coupling OpenFOAM to Open SOurce 1D code
Old   December 23, 2015, 04:43
Default Coupling OpenFOAM to Open SOurce 1D code
BastiL
bastil is on a distinguished road
Hi all,
I am interested in a coupling interface between OpenFOAM and a OpenSource 1D combustion code. For this I have OpenWOM in mind (http://www.cmt.upv.es/OpenWam.aspx). My focus is on coupled 1D-3D ICE simulations.
I know there has been a OpenFOAM-GT-Power coupling but is there something else?
Thanks
BastiL
bastil is offline   Reply With Quote
Old   December 23, 2015, 05:04
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
If OpenWOM have user-defined functions or something similar, then you can couple it with OpenFOAM with functionObjects of fvOptiosn - depending on what you want to do exactly
mkraposhin is offline   Reply With Quote
Old   December 23, 2015, 05:37
BastiL
I have taken a look into the recent sources:
https://github.com/CMT-UPV/OpenWAM
It has some kind of preparation since similar things have already been done for Fluent as described here:
https://riunet.upv.es/bitstream/hand...sisUPV3883.pdf
I will keep you posted.
Old   December 23, 2015, 12:15
mkraposhin's Avatar
Matvey Kraposhin
If you will propose simple example of interaction between OpenFOAM and OpenWAM, i can help you with functionObject and fvOptions implementation
Old   December 23, 2015, 12:27
BastiL
What do you mean with simple example? Basically I want to do two things:
  • exchange wall temperature from OpenWAM to OpenFOAM to calculate solid temperatures of engine head and block of transient temperature cycles
  • Exchang epressure velocity an species at boundary conditions to combine 1D and 3D, eg. run exhaust system in 3D and get transient BCs from ObenWAM in 1D.
These are simiar examples that are already available in the OpenFOAM-GTPower coupling. My second point is also described in my second link above, including an FLUENT UDF.
Old   December 24, 2015, 12:52
mkraposhin's Avatar
Matvey Kraposhin
sorry for the long delay
It is a good practice to create a simple geometry case for example, for circular pipe which can exchange heat with external wall. Pipe is modelled with OW, wall is modelled with OF.
I found too many letters by this link.
Maybe it will be much faster to make simple exchange of mass/heat between OF and OW. And only next step can consist of understanding how different people solve similar such problems.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
