multi patch boundary condition
Old   March 31, 2016, 14:37
Default multi patch boundary condition
ZHENKAI ZHAO
zhaozhenkai is on a distinguished road
Hi, guys,
I am try to simulate a multi-body case using pimpleDyMFoam. I have got three moving patches so I have set their U BCs as movingWallVelocity. I use external programme to calculate their position and add the new position on to the patch using methods below:
pointDisplacement_.boundaryField()[patchID2] == pointsN2 - pointsI2;
the "patchID2" is the patch name.
However, when i run it, the simulation blows up quickly, and I have tested the case with only one moving patch and it worked fine. I have also used other BCs for the moving patches like zeroGradient which is not correct, and there is no blow up on the fly.
I wonder if there is a limitation on using movingWallVelocity BC or the problem is related to the mesh.update().
it may be unclear about my statements. If you need more information, please tell me.
ZHENKAI
zhaozhenkai is offline   Reply With Quote
Old   April 5, 2016, 10:45
ZHENKAI ZHAO
Hi, guys,
ZHENKAI
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 36 January 7, 2015 00:31
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
