coordSys_ definition?
Old   August 9, 2016, 14:06
Default coordSys_ definition?
Dominic
Verse is on a distinguished road
Hello there,
I was wondering where the coordSys_ variable was defined? I see an instance of it in forces.C (more specifically, coordSys_.origin()), but I see in no other file where it is defined in. I am definitely missing a part of this puzzle.
Verse is offline   Reply With Quote
Old   August 10, 2016, 11:45
Mahdi Hosseinali
anishtain4 is on a distinguished road
running
cd $FOAM_SRC
grep -nr coordSys_
gives you a list of all the places where it is used and you can find where it is defined.
As it seems you are dealing with forces.C, I guess the closest to your case would be line 235 of of forces.H which reads:
coordinateSystem coordSys_;
and if you need to know more about it, you'll just search it in Doxygen which gives you this:
http://www.openfoam.com/documentatio...ml/a00443.html
anishtain4 is offline   Reply With Quote
Problem with residual and their definition! batta31 OpenFOAM Running, Solving & CFD 5 July 18, 2016 10:39
rhoThermo.correct()'s definition sharonyue OpenFOAM Programming & Development 1 June 30, 2015 09:44
(AutoGRID 5) Problem in Geometry definition of propeller venkat_aero2007 Fidelity CFD 14 July 31, 2012 14:05
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
