Meaning of MRF.correctBoundaryVelocity(U) and fvOptions(U) in the UEq file.
Old   September 28, 2016, 13:31
Question Meaning of MRF.correctBoundaryVelocity(U) and fvOptions(U) in the UEq file.
Mirage
Mirage is on a distinguished road
I am using OF3.0.1 and I am trying to edit an already edited pisoFoam solver written in OF 2.3.
I wrote the UEq in a separate .H file. The solver is working but I am sure, if i am doing it correctly.
Here is what i wrote in the new UEq file:
turbulence->correct();
fvVectorMatrix UEqn
    fvm::ddt(U)
  + fvm::div(phi, U)
  + turbulence->divDevReff(U)
    flowDirection*gradP
UEqn.relax();
if (piso.momentumPredictor())
    solve(UEqn == -fvc::grad(p));
and here is the new pisoFoam .C file:
       Info<< "Time = " << runTime.timeName() << nl << endl;
        // Pressure-velocity PISO corrector
            #include "UEqn.H"
            // --- PISO loop
            volScalarField rAU(1.0/UEqn.A());
            while (piso.correct())
                #include "pEqn.H"
                    U.correctBoundaryConditions();
Here is the old pisoFoam solver:
while (runTime.loop())
       // #include "readPISOControls.H"
        #include "CourantNo.H"
    #include "setDeltaT.H" // added
            // Momentum predictor
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
        flowDirection*gradP
            UEqn.relax();
            if (momentumPredictor)
In the original pisoFoam (OF3.0.1) the UEq was also separated from the main .C file:
// Solve the Momentum equation
MRF.correctBoundaryVelocity(U);
fvVectorMatrix UEqn
    fvm::ddt(U) + fvm::div(phi, U)
  + MRF.DDt(U)
    fvOptions(U)
UEqn.relax();
fvOptions.constrain(UEqn);
    fvOptions.correct(U);
As you can see that UEq files look different. I was wondering, if I should use the functions
and
fvOptions(U)
Please let me know if you need any other informations.
Any advice will be greatly appreciated, thanks in advance
Mirage is offline   Reply With Quote
Old   September 29, 2016, 02:55
TobM is on a distinguished road
You only need these, if you want to use fvOptions or MRF. If not, you don't need them.
TobM is offline   Reply With Quote
