September 8, 2018, 14:08 |
How to use Openfoam with Clion
Matte Wang
Rep Power: 7 |
I saw some introductions about how to use Openfoam with some IDE(qt creator eclipse) in Openfoam Wiki. However, I don't find any information about Clion.
Are there some problems in Clion When combining the Openfoam? Could anyone tell me the reason or give me some introductions? Another question is that is qt creator performing well when it combines with openfoam? |
April 17, 2019, 15:45 |
CLion & OpenFOAM
Turns out CLion is suited for CMake.
I can at least build a library after launching from terminal with OpenFOAM environment and setting up custom toolchain with custom targets. Looks like better option is KDevelop or Emacs.
practice makes perfect |
November 14, 2019, 09:15 |
Clion for OpenFOAM
SSSSS
Rep Power: 14 |
Clion can read compile_commands.json as well as CMakeList.txt.
Once compile_commands.json is read, you can have fun with Clion. I am not sure about compile in Clion cause I only use Clion when intellisense is needed. compile_commands.json can be generated with Bear (Build EAR). Instead of use wmake command, use bear wmake then you can have compile_commands.json. |
clion |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 1 | November 7, 2015 15:16 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 03:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
