reading in a string
Like Tree8Likes
  • 8 Post By l_r_mcglashan
Old   August 3, 2009, 18:06
Default reading in a string
Scott Ripplinger
sripplinger is on a distinguished road
I'm in the middle of writing some code for colloidal particle transport based on the solidParticle class. I would like to be able to read in the name of the model I want to use. For instance, in the particleProperties file I am trying to add a vdwModel variable which is read in as a string ("Gregory" or "SchenkelKitchener"). This would then be used later in the code to specify which force model I want to use.
My question is exactly how do I read in a string? Something along the lines of readScalar is what I'm looking for, but if I need to rethink how I'm doing this, then I'll listen to any suggestions you have.
sripplinger is offline   Reply With Quote
Old   August 4, 2009, 05:36
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I assume you're familiar with something like this:
scalar variable = readScalar(dictionary.lookup("variableName"));
Well you can have:
word variable = word(dictionary.lookup("variableName"));
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   August 4, 2009, 11:28
Scott Ripplinger
Yes! I think that is exactly what I am looking for. I'll give it a go and see if it works for me.
i/o, input, read string
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 06:37
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam jlpelerin OpenFOAM Meshing & Mesh Conversion 4 April 25, 2011 16:56
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
[Commercial meshers] FluentMesh conversion problem waynezw0618 OpenFOAM Meshing & Mesh Conversion 12 November 30, 2006 23:12
