Compiling modified patchAverage tool
Old   October 15, 2009, 10:40
Default Compiling modified patchAverage tool
Bjw
Björn Westendorf
Bjw is on a distinguished road
I'm trying to modify the patchAverage tool, so that the calculation result will be written into a simple text file. In a simple C++ app, including
#include <iostream>
#include <fstream>
and adding the following simple code:
ofstream results;
results.open ("results.dat", ios::out | ios::app);
results<< sumField << endl;
results.close;
should do the job. Howewer, I cannot compile that tool. wmake will produce the following:
Making dependency list for source file patchAverageToFile.C
SOURCE=patchAverageToFile.C ;  g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3  -DNoRepository -ftemplate-depth-40 -I/home/stss2/OpenFOAM/OpenFOAM-1.5.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stss2/OpenFOAM/OpenFOAM-1.5.x/src/OpenFOAM/lnInclude -I/home/stss2/OpenFOAM/OpenFOAM-1.5.x/src/OSspecific/Unix/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/patchAverageToFile.o
patchAverageToFile.C: In function ‘int main(int, char**)’:
patchAverageToFile.C:96: error: ‘ofstream’ was not declared in this scope
patchAverageToFile.C:96: error: expected `;' before ‘results’
patchAverageToFile.C:97: error: ‘results’ was not declared in this scope
patchAverageToFile.C:97: error: ‘ios’ has not been declared
make: *** [Make/linux64GccDPOpt/patchAverageToFile.o] Fehler 1
Can somebody tell me how to fix that?
Thanks, Björn
Bjw is offline   Reply With Quote
Old   October 16, 2009, 00:10
Default what's your object ?
jingjing
zhajingjing is on a distinguished road
what's the object of your modified patchAverage file? the original patchAverage tool already has the ability to produce data.If you want to get a data file,you just run the tool,
just like this: patchAverage fieldName patchName > dataFileName
then you can get the data file
So I don't know your real object.If the object is just to get a data file,you can do as above,
jingjing
zhajingjing is offline   Reply With Quote
Old   October 16, 2009, 04:37
Bjw
Björn Westendorf
Well, I need to parse the calculation result with another application for automated post-processing. So it would be nice to just write out the result rather than writing the whole screen output to file.
Old   October 16, 2009, 04:47
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Try sticking 'std::' in front of ofstream, or 'using namespace std' before main.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   October 16, 2009, 05:31
Bjw
Björn Westendorf
Great, that worked, thank you very much! ofstream and ios are obviously not declared in the foam namespace.
compile, patchaverage
Problems while using the sample post-procesing tool svens OpenFOAM Post-Processing 5 September 2, 2010 11:13
[mesh manipulation] ScalePoints tool cedric_duprat OpenFOAM Meshing & Mesh Conversion 6 September 19, 2008 03:15
tool for approximation of condition number rt Main CFD Forum 6 June 24, 2006 02:42
Parametrical tool? Renaud FLUENT 0 May 25, 2006 04:51
Modified Equation for CFX algorithm Craig Johansen CFX 0 August 27, 2004 23:02
