January 14, 2023, 13:16 |
Summing two volScalarFields
Rep Power: 3 |
I would like to know what OpenFOAM does to the boundaryField when summing two volScalarFields. Say : Code:
volScalarField f1 = p1 + p2; Now, let us say that p1 only has fixedValue boundary conditions and p2 only has fixedGradient. What ends up in f1? Does openfoam take the fixedGradient values from p2, estimates the value on the face and sums it up it with the fixedValue of p1? If so, where is this made in the code? |
January 14, 2023, 14:48 |
Boundary conditions are typically applied *after* summing up contributions in the eon. Details are in eg the book by Moukalled, see https://link.springer.com/book/10.10...-3-319-16874-6.
Edit: eon => eqn or equation Last edited by dlahaye; January 15, 2023 at 11:26. |
January 15, 2023, 07:10 |
#3 | |
Rep Power: 3 |
Thanks for the comment. What does "eon" mean? Would you be so kind as to tell me where this information is located in the book? So far, I was not able to find this information. |
January 17, 2023, 13:58 |
Rep Power: 3 |
This section is on boundary conditions for incompressible NS.
I would believe that the relevant part is : "The unknown boundary pressure pb is extrapolated from the interior solution using either a truncated Taylor series expansion around point C such that pressure is found from:" So, when I sum two `volScalarField`s, the values that exist in the boundary with the `calculated` type are a reflection of this. |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
volVectorField from 3 volScalarFields without for loop | Houthuys | OpenFOAM Programming & Development | 2 | June 6, 2017 05:43 |
Multiple volScalarFields using List<volScalarField> | vbchris | OpenFOAM Programming & Development | 6 | September 14, 2014 06:38 |
foamToEnsight does not convert all volScalarFields | stevenbeale | OpenFOAM Post-Processing | 2 | February 14, 2014 04:20 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
