Looping over a volScalarField in a parallel run |
June 1, 2010, 08:46 |
Florian Ettner
Dear all,
I'd like to do some on-the-run monitoring of my computation where I am interested in a temperature front. Actually, of all the cells in my domain where the temperature exceeds 1000 K, I'd like to determine the one which has the highest x-coordinate. My code looks like this: Code:
label maxindex=0; forAll(mesh.C(),i) { if(T[i]>1000.0) { if(mesh.C()[i].component(0) > mesh.C()[maxindex].component(0)) maxindex=i; } } Info<< "front @ " << mesh.C()[maxindex] << endl; Regards, Florian |
June 1, 2010, 09:55 |
Niklas Nordin
Rep Power: 29 |
ooo, a well formulated problem with a simple answer, my favourite
you cant use the index cause it only makes sense on the own processor. I would do it like this. Code:
scalar xMax = -1.0e+10; forAll(mesh.C(),i) { if(T[i]>1000.0) { if(mesh.C()[i].component(0) > xMax) { xMax = mesh.C()[i].component(0); } } } reduce(xMax, maxOp<scalar>); Info<< "front @ " << xMax << endl; |
June 2, 2010, 14:26 |
Florian Ettner
Thank you Niklas,
the reduce command should read Code:
reduce(xMax, maxOp<scalar>()); A more tricky problem: I also want to know the y and z coordinate of the location, where the highest x coordinate is (not the maximum y and z coordinate). So a separate reduce on the scalars won't work. Code:
scalar xMax = -1.0e+10; vector maxVector(-1e10,0.0,0.0); forAll(mesh.C(),i) { if(T[i]>1000.0) { if(mesh.C()[i].component(0) > xMax) { xMax = mesh.C()[i].component(0); yMax = mesh.C()[i].component(1); zMax = mesh.C()[i].component(2); maxVector = mesh.C()[i]; } } } reduce(xMax, maxOp<scalar>); Info<< "front @ " << xMax << endl; Thanks, Florian |
June 4, 2010, 02:49 |
Niklas Nordin
Rep Power: 29 |
That was a bit trickier...
I dont know if there's such an operation already implemented, but I would transfer the location vector for each coordinate to the main processor and do the comparison there. Here's a piece of code that generates a random vector on each processor and sends it to the 0-processor, it should be straightforward to apply it to your case. You might wanna put it inside an if(Pstream:: parRun()) if you want it to work for both serial and parallell runs. (edit:: actually its not necessary) Code:
Random rnd(0); // get the number of processors label n=Pstream::nProcs(); // generate a random vector, since the seed is the same for all procs they will be the same // if we only do it once vector localV = rnd.vector01(); for(label i=0; i<Pstream::myProcNo(); i++) { localV = rnd.vector01(); } // print the vector on the processor (so we can compare it later when we print it on the main proc) Sout << "[" << Pstream::myProcNo() << "] V = " << localV << endl; if (Pstream::myProcNo() == 0) { List<vector> allV(n, vector::zero); allV[0] = localV; for(label i=1; i<n; i++) { // create the input stream from processor i IPstream vStream(Pstream::blocking, i); vStream >> allV[i]; } // print the list of all vectors on the main proc Info << allV << endl; } else { // create the stream to send to the main proc OPstream vectorStream ( Pstream::blocking, 0 ); vectorStream << localV; } |
June 16, 2010, 03:58 |
Florian Ettner
Thank you, it seems to work fine!
December 3, 2016, 08:56 |
coded functions with forAll have similar problems with parallel execution
#6 | ||
a
Rep Power: 11 |
this is a coded function added in controlDict,
please help.... All suggestions are most welcome. Thanks and regards. |
December 10, 2016, 18:04 |
Sergei
Rep Power: 21 |
December 11, 2016, 04:53 |
#8 | ||
a
Rep Power: 11 |
Thanks Zeppo.
syntax wise (reduce(volIntegral, maxOp<scalar>()) works, but the answer of serial and parallel is different. parallel output at one time-step. Quote:
December 11, 2016, 11:24 |
Sergei
Rep Power: 21 |
1. You might want to use a built-in feature instead of developing your own code. There's a function object volRegion (http://cpp.openfoam.org/v4/a06355_source.html)
pIntegral { type volRegion; libs ("libfieldFunctionObjects.so"); operation volAverage; regionType all; fields ( p ); } 2. Nevertheless, if you want to "reinvent the wheel" (or practice in OpenFOAM/C++ programming, if you like to think of it this way ) look at how this function object is implemented Code:
// "src/functionObjects/field/fieldValues/volRegion/volRegion.H" 157 template<class Type> 158 bool Foam::functionObjects::fieldValues::volRegion::writeValues 159 ( 160 const word& fieldName 161 ) 162 { 163 const bool ok = validField<Type>(fieldName); 164 165 if (ok) 166 { 167 Field<Type> values(setFieldValues<Type>(fieldName)); 168 scalarField V(filterField(mesh().V())); ... 176 // Combine onto master 177 combineFields(values); 178 combineFields(V); ... 181 if (Pstream::master()) 182 { 183 Type result = processValues(values, V, weightField); ... 211 } 212 } 213 214 return ok; 215 } Code:
// "src/functionObjects/field/fieldValues/volRegion/volRegion.H" 74 template<class Type> 75 Type Foam::functionObjects::fieldValues::volRegion::processValues 76 ( 77 const Field<Type>& values, 78 const scalarField& V, 79 const scalarField& weightField 80 ) const 81 { 82 Type result = Zero; 83 switch (operation_) 84 { ... 105 case opVolAverage: 106 { 107 result = sum(V*values)/sum(V); 108 break; 109 } ... 149 } 150 151 return result; 152 } Code:
// "src/functionObjects/field/fieldValues/fieldValue/fieldValueTemplates.C" 32 template<class Type> 33 void Foam::functionObjects::fieldValue::combineFields(Field<Type>& field) 34 { 35 List<Field<Type>> allValues(Pstream::nProcs()); 36 37 allValues[Pstream::myProcNo()] = field; 38 39 Pstream::gatherList(allValues); 40 41 if (Pstream::master()) 42 { 43 field = 44 ListListOps::combine<Field<Type>> 45 ( 46 allValues, 47 accessOp<Field<Type>>() 48 ); 49 } 50 } Code:
reduce(volIntegral, maxOp<scalar>()); reduce(volIntegralV, maxOp<scalar>()); Code:
reduce(volIntegral, sumOp<scalar>()); reduce(volIntegralV, sumOp<scalar>()); |
December 13, 2016, 05:32 |
a
Rep Power: 11 |
Thanks Zeppo for a informative reply!
I will try this Code: reduce(volIntegral, sumOp<scalar>()); reduce(volIntegralV, sumOp<scalar>()); and get back to you! |
Unable to run OF in parallel on a multiple-node cluster | quartzian | OpenFOAM | 3 | November 24, 2009 13:37 |
Parallel run diverges, serial does not | SammyB | OpenFOAM Running, Solving & CFD | 1 | May 10, 2009 03:28 |
Time Parallel run | Dr. FLow Squad | FLUENT | 5 | October 11, 2007 03:18 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 06:33 |
How to run parallel in ICEM_CFD? | Kiddo | Main CFD Forum | 2 | January 24, 2005 08:53 |
