how to impose fixed value at a point (or region) during calculation ?
Like Tree2Likes
Old   July 5, 2010, 05:34
Default how to impose averaged field equal to 0 at a point during calculation ?
Cyp
Cyprien
Cyp is on a distinguished road
Hi!
In my subject, I need to solve equations with a condition of average-field-equal-to-zero.
I defined the average of the T field as :
T_moy=fvc::domainIntegrate(T) / V
where V is the volume of the domain.
how can I impose T_moy=0 during the calculation ?
Thank you for your precious help.
Cyp is offline   Reply With Quote
Old   July 5, 2010, 07:23
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi Cyp,
Do you went to impose a value on certain points or do you search for a condition which will make sure that after solving the transport equation your field T is in accordance with your implied condition.
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   July 5, 2010, 08:57
Cyp
Cyprien
I want to be sure that after my calculation, the implied condition is satisfied.
In Comsol I imposed a constraint ( moy(T)=0) on one point (it is sufficient). what is the equivalent on OpenFOAM ?
Old   July 6, 2010, 02:40
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
To impose values at specified cells, you'd want the fvMatrix::setValues() method.
http://foam.sourceforge.net/doc/Doxy...bc49953b884184
olesen is offline   Reply With Quote
Old   July 6, 2010, 03:59
Cyp
Cyprien
thank you for your answer !
The setValues definition precises that the imposed values are field value. In my case, I need to imposed a value for the average of a field over the domain.
Do you think setValue is a good hint for my problem ?
Old   July 6, 2010, 06:40
Stefan Herbert
herbert is on a distinguished road
Hi Cyp,
I think it would be easier for us to help you, if you would show us your equation and boundary conditions in detail.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   July 6, 2010, 08:52
Cyp
Cyprien
Here is the problem I want to solve with OpenFOAM :
http://img5.imageshack.us/i/problemaaj.jpg/
It is the last condition ( <s_{gamma}>^{gamma}=0) I was talking about..
https://docs.google.com/leaf?id=0B3b...YWRlODRk&hl=en
Last edited by wyldckat; September 3, 2015 at 18:03. Reason: disabled embedded images
Old   July 8, 2010, 09:31
Cyp
Cyprien
I am a bit lost...
Such a condition (to impose averaged field on a region equal to 0) is fundamental in my calculation.
Can anyone give me a hint ??
Old   July 8, 2010, 11:47
Stefan Herbert
Hi Cyp,
I'm still waiting for your equation and BC's. It would really help me to help you.
Regards,
Stefan
Old   July 8, 2010, 11:49
Cyp
Cyprien
can't you see the picture in my previous message ??
Old   July 8, 2010, 11:54
Stefan Herbert
No I can't. Sorry. But now I can take a look.
Thanks.
Old   July 15, 2010, 12:21
Cyp
Cyprien
Hi Herbert (and all of you of course!)
I still looking for a solution to my problem (it is a very fundamental point in my developpment).
Do you think I can use the setValue (or setReference) utility in my case ?
Thank you,
Cyprien
Old   July 16, 2010, 03:01
Stefan Herbert
Hi Cyprien,
I did not come up to a solution as well. But I think you aren't able to use setValues or setReference.
Can you solve the equation without boundaries fixing values (only gradient bc's)? In that case you could solve the field using setReference and subtract the average field value afterwards.
I don't think there is a solution for your problem already existing in OpenFOAM.
Regards,
Stefan
Old   July 16, 2010, 05:44
Cyp
Cyprien
Hi!
In fact it is exactly what I do for the moment (subtract the average field value afterwards). But it only works with simple source terms. When I try this a more complicated source term, this method doesn't converge to a solution..
Old   July 19, 2010, 08:30
Cyp
Cyprien
Someone told me that I should directly insert my problem into the matrix I want to solve. If I understand what it is suggested, I declare my problem as
fvScalarMatrix TEqn
        fvm::ddt(rho,T)
      +fvm::div(phi,T)
      -fvm::laplacian(rho*DT,T)
Then I calculate the average value of my T field over the gamma phase by
T_moy=domainIntegrate(phase_gamma*T)/V_gamma
where V_gamma is the volume of the gamma phase
The next step is to enlarge my TEqn matrix by adding T_moy in the last position of the diagonal and zeros elsewhere.
Finally I should get the result solving
solve(TEqn == f)
where f is the original source term of my problem with an additionnal 0 at the last position.
What do you think of this method ??
How can I enlarge my matrix ??
Old   July 20, 2010, 10:06
Cyp
Cyprien
In fact, I found a very easiest way to proceed!!
I just have to fix a value at a point (with setReference) which assure the convergence of my problem. Then I find out my real fields by subtracting the average value of the calculated field! I post the code if someone is interested by such a problem :
while(runtime.loop())
#   include "readSIMPLEControls.H"
    for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
    fvScalarMatrix TEqn
           fvm::ddt(rho,T)
          +fvm::div(phi,T)
          == f
     TEqn.setReference(TRefCell,TRefValue)
     TEqn.solve()
T= phase_gamma*(T-fvc:domainIntegrate(phase_gamma*T)/V_gamma)
  +phase_beta *(T-fvc:domainIntegrate(phase_gamma*T)/V_gamma)
In the next step of my project, I need to do similar calculation with a vector field B. I want to use a similar strategy but the setReference seems to work only with scalar...
How can I fix the value of my vector B at a point ?
Old   July 20, 2010, 11:15
Stefan Herbert
Hi Cyp,
the you can use setValues. Even if you want to fix only one point, setValues needs a list of points to be fixed. The following should work:
label refCell = 12345;
labelList refCells (1,refCell);
vectorField refValues (1, vector(0,0,0));
TEqn.setValues(refCells, refValues);
Regards,
Stefan
wayne14 and Michael@UW like this.
Old   July 21, 2010, 03:18
Cyp
Cyprien
Hi Stefan!
It perfectly works !! Thank you very much!
Old   August 3, 2010, 09:19
Default accessing cells from a patch
  #19
George Pichurov
jorkolino is on a distinguished road
Does anyone know how can I access the cells from a patch with name patchname ? I want to run a procedure (particle injection) for each of the cells. I have the code, but I need the cell index.
jorkolino is offline   Reply With Quote
Old   February 24, 2012, 05:41
Samuele Z
samiam1000 is on a distinguished road
Hi everyone.
First of all, I would like to answer to this:
I think you can find whay you want in the case_path/constant/polyMesh folder where there are different files.
Also, I have a question: I want to impose a fixed value of a temperature in a certain volume of my domain.
How can I do this? Should I use the fvMatrix::setValues() method?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Torque Calculation at Arbitrary Point Mojtaba Main CFD Forum 0 February 14, 2009 00:58
Calculation torque on arbitrary point Mojtaba Main CFD Forum 0 February 9, 2009 00:08
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
Grid refinement with wall functions Mark Render Main CFD Forum 8 May 2, 2000 07:09
Non-uniform grid calculation Aspens Main CFD Forum 1 February 23, 2000 14:15
