loop through structured mesh by i,j,k
Old   July 20, 2010, 11:27
Default loop through structured mesh by i,j,k
akidess's Avatar
Anton Kidess
Hello all,
I know I can loop through all cells of a mesh using forAll(mesh.cells(),celli). However, this won't tell me anything about the geometric location of the neighbors. I'd like to only use the neighbors on a certain axis for my further calculations. Does anyone have an idea?
In pseudo code, in 2D:
for (i =0; i < mesh.max_i; i++)
     for (j =0; j < mesh.max_j; i++)
           // calculation involving mesh.cell[j-1], mesh.cell[j], mesh.cell[j+1]
Old   July 20, 2010, 12:41
Sandeep Menon
deepsterblue will become famous soon enough
I suppose you could look at cell-faces, take the dot-product of the unit face-normal with the axis-direction that you want, and check its magnitude. You can then choose the owner/neighbour of those faces to get the adjacent cell.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   July 21, 2010, 05:01
akidess's Avatar
Anton Kidess
Thanks, that got me started! Now I'm facing a weird problem though: Every now and then, instead of a sensible neighbour cellID, I get something way off, eg.
inner circle, celli: 932
neigh: 962 //makes sense
neigh: 1751339886 //can't be, grid only has like 1200 cells, using it to access a field naturally leads to a seg fault
Any Idea why that would be happening and how to avoid it?
vector axis(0, 1, 0);
    forAll( mesh.C(), celli)
            // Neighbour and owner cells to given face
            const unallocLabelList & nei = mesh.neighbour();
            const unallocLabelList & own = mesh.owner();
            // This is a list of faces of which the cell is build
            const cell& cProp = mesh.cells()[celli];
            // Loop over all faces
            forAll(cProp, facei)
                label owner = own[cProp[facei]];
                label neigh = nei[cProp[facei]];
                //find faces in y-direction
                if (mag(mesh.Sf()[facei] & axis) > 0)
                     Info << "celli: " << celli << endl;
                     if (owner == celli) {
                         Info << "neigh: " << neigh << endl;
                     } else { // neigh == celli
                         Info << "owner: " << owner << endl;
Old   July 21, 2010, 05:10
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
That would occur, if you are requesting a neighbour for a boundary face. You should make a conditional like
if (cProp[facei] < own.size())
    // Can ask for both owner and neighbour
else
    // Only owner exists
Cheers,
Niels
ngj is offline   Reply With Quote
Old   July 21, 2010, 05:27
akidess's Avatar
Anton Kidess
So my guess is that the large number are boundary cells and could be just filtered out by comparing with mesh.size() [edit: Sorry Niels, didn't see your post while writing this one]. However, I now noticed that I'm not seeing two neighbors as expected on a 2D mesh, but three! Whats going on? Here is an image of cellIDs I got out of paraview.
Looking at cell 31, I want to get 1 and 61 as output. Instead I'm getting:
celli: 31
neigh: 61
owner: 31
celli: 31
owner: 31
neigh: NULL
celli: 31
neigh: 31
owner: 30
Why is there an inner face, and why am I getting the left neighbor instead of the lower one?
cells, index, loop, mesh, neighbor
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
need reference for structured mesh generation cfduser03 Main CFD Forum 3 September 7, 2009 09:58
Structured mesh of a 3d sharp trailing edge Gilles Main CFD Forum 2 May 23, 2008 13:23
