Neumann boundary conditions
Like Tree2Likes
Old   August 11, 2010, 09:35
Default Neumann boundary conditions
Martin80 is on a distinguished road
I want to change my boundary conditions during runtime. For the Dirichlet conditions I have found a way to set up the conditions in the code:
I have choosen fixedValue for the boundary type and I updated it in the code using:
U.boundaryField()[patchI]== mynewScalarField;
I have tried the same with fixedGradient type for a Neumann Condition but it doesn't update the gradient value. (I have reviewed it with .snGrad()).
Maybe someone can give me a useful hint,
thanks, m.
Martin80 is offline   Reply With Quote
Old   August 16, 2010, 07:47
Stefan Herbert
herbert is on a distinguished road
Hi Martin,
you have to do a refCast. Example:
fixedGradientFvPatchVectorField& gradUPatch=refCast<fixedGradientFvPatchVectorField>(U.boundaryField()[patchI]);
scalarField& gradUField =  gradUPatch.gradient();
After this you can edit gradient values in gradUField.
Of course you have to include "fixedGradientFvPatchFields.H" in your header.
Regards,
Stefan
babakflame and randolph like this.
herbert is offline   Reply With Quote
Old   August 16, 2010, 08:33
astein is on a distinguished road
Hi!
snGrad() has nothing to do with the gradient which you want to impose with your boundary condition, it is some geoemetrical quantity.
The fvPatchField is a field of quantities, which are applied as fixed gradients. Therefore, you have to write the wanted values to the field the same way you do it for the fixedValue stuff.
I hope you get the point...
Cheers, Andreas.
astein is offline   Reply With Quote
Old   August 16, 2010, 13:53
Hi Stefan,
I have already got the same answer from somebody else but thank you very much - this is exactly what I was seeking for. [.gradient() is not a member function of "volVectorField" but of "fixedGradientFvPatchVectorField"].
Hi Andreas,
I don't think u r right, U.boundaryField()[patchI].snGrad() in that case should show me the current boundary condition of the fixedGradient bc object.
B.r.,
Martin.
Old   August 16, 2010, 13:59
Nadeem
ubaid is on a distinguished road
HAve u guys got the solution how to update the value of gradient, I think my problem is also similar to yours.
that is expressed below:
volScalarfield field
IOobject(fieldName,runtTime.timeName(),mesh,IOobje ct::NO_READ,IOobject::AUTO_WRITE),
mesh,
dimensionedScalar(fieldName,dimTemperature, 200),
"fixedGradient"
forAll(field.BoundaryField(),patchID)
field.boundaryField()[patchID]==30;
As an output of this code am getting something different.
that is.
boundaryField
Inlet
type fixedGradient;
gradient uniform 0;
and so on;
but I am interested to get output as below:
boundaryField
inlet
type fixedGradient;
gradient uniform 30;
ubaid is offline   Reply With Quote
Old   August 17, 2010, 03:03
Martin,
at the end, its the same.
What herbert is proposing is to copy (with the refCast) the reference of the fvPatchField to a new vectorField and editing THAT. Because of the reference, that still modifies the original field.
But you could write to your fixedGradientFvPatchVectorField directly, without giving it a new name. Just try it :-)
And - snGrad is definitely returning some geometrical stuff from the mesh, take a look at doxygen.
As long as it works there is no need to worry...
Have fun,
Andreas.
Old   August 17, 2010, 07:31
Nadeem
Originally Posted by astein View Post
Martin,
Have fun,
Andreas.
Thanks, surely it works, I read this thread little bit late thoroughly and atlast i did it.
Old   September 6, 2010, 05:37
Default Help Neumann boundary condition in fluent
cfm
cfm is on a distinguished road
Hi!!
I need to define an output Neumann boundary condition using fluent. the condition is dc/dn=0, where c is the concentration of a certain species and n is the normal versor to the output face.
How can I do this? Thanks!
cfm is offline   Reply With Quote
Old   October 14, 2010, 09:28
Cyp
Cyprien
Cyp is on a distinguished road
Originally Posted by herbert View Post
Hi Martin,
Regards,
Stefan
Hi Stefan and everybody,
I trying to implement neumann BC with your method but I had a fail during the compilation. I have merely copy your piece of code in my main.C file and I included "fixedGradientFvPatchFields.H" in my header.
I get the following error :
applications/twoDarcyF> wmake
Making dependency list for source file twoDarcyF.C
SOURCE=twoDarcyF.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/gemp/csoulain/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/gemp/csoulain/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/gemp/csoulain/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/twoDarcyF.o
twoDarcyF.C: In function ‘int main(int, char**)’:
twoDarcyF.C:74: error: invalid initialization of reference of type ‘Foam::scalarField&’ from expression of type ‘Foam::Field<Foam::Vector<double> >’
make: *** [Make/linux64GccDPOpt/twoDarcyF.o] Erreur 1
Do you have any idea where I am wrong ?
Regards,
Cyp
Cyp is offline   Reply With Quote
Old   October 14, 2010, 09:44
It should be:
vectorField& gradUField = gradUPatch.gradient();
(in case U is a volVectorField)
M.
Old   October 14, 2010, 10:26
Cyp
Cyprien
Ok. Thank you very much. It compiles now.
But in case U is a volScalarField (a pressure field for example)? The code of Hebert should works, shouldn't it ?
Old   October 14, 2010, 10:51
No, i think in that case (for a volScalarField) you have to modify the first expression of Stefan's code in an appropriate way.
M.
Old   October 14, 2010, 12:33
Cyp
Cyprien
I have a problem of understanding: the gradient of a scalar should be a vector. So the following snippet should work:
label patchID = mesh.boundaryMesh().findPatchID("inlet");
fixedGradientFvPatchVectorField& gradUPatch=refCast<fixedGradientFvPatchVectorField>(p.boundaryField()[patchID]);
gradUField = -(inv(M)&U)+rho*g;
where M is a tensor, U the velocity field (vector), rho a volScalarField, and g the vector acceleration.
In fact, it compiles but fails while running:
Time = 0.1
--> FOAM FATAL ERROR:
Attempt to cast type fixedValue to type fixedGradient
    From function refCast<To>(From&)
    in file /opt/openfoam171/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
I can't see my mistake..
Old   October 14, 2010, 12:49
You define the outer normal gradient (grad p * n) [n is the surface outer normal direction]
let p be a scalarF and V a vectorF then:
grad(p) is a vectorF -> (grad(p)) *n is a scalarF
grad(V) is a tensorF -> (grad(V)) *n is a vectorF
I hope it helps, M.
Old   October 14, 2010, 13:14
Cyp
Cyprien
Thank you very much Martin. It helps me much in the understanding !
So I changed the code as :
fixedGradientFvPatchScalarField& gradUPatch=refCast<fixedGradientFvPatchScalarField>(p.boundaryField()[patchID]);
Now, according to your definition, if I understand correctly, I need to get the projection of my field -(inv(M)&U)+rho*g on the patch : (-(inv(M)&U)+rho*g ) *n. Is it possible to do such a thing ?
Old   October 14, 2010, 13:41
Cyp
Cyprien
I think it could work with :
gradUField = linearInterpolate(-(inv(M)&U)+rho*g) & mesh.Sf();
Old   October 14, 2010, 14:14
The normal surface vector field on the boundarypart patchID is:
vectorField n = mesh.Sf().boundaryField()[patchID]
Take care that the left part of your calculation is finally also a vectorField on the appropriate domain (boundaryField()[patchID]).
M.
Old   October 18, 2010, 11:53
Cyp
Cyprien
Hi Martin!
Thank you very much for your answer. I am not sure to understand very well...
I tried:
vectorField n = mesh.Sf().boundaryField()[patchID];
and either
gradUField = (-(inv(M)&U)+rho*g)&n
or
gradUField = (-(inv(M)&U)+rho*g)*n
or
gradUField = linearInterpolate(-(inv(M)&U)+rho*g)&n
but it does not compile... Do you see my mistake ??
Old   October 25, 2010, 10:28
Cyp
Cyprien
Hi!
I succed in the compilation using this piece of code :
        vectorField UU_beta = U_beta.boundaryField()[patchID];
        tensorField MM_beta = M_beta.boundaryField()[patchID];
        tensorField invMM_beta=inv(MM_beta);
        gradUField = -((invMM_beta&UU_beta)&n)+(rho_beta.boundaryField()[patchID]*(g.value())&n);
I set up a fixedValue at the inlet for my U_beta field but when I plot the results, the U_beta value is different that the one I chose...
Did I miss something ??
Regards,
Cyp
Old   October 26, 2010, 05:00
Stefan Herbert
Please realize that you are editing the BC for p with your code
Originally Posted by Cyp View Post
If you want to edit BC for U, you have to change it in the following way
       fixedGradientFvPatchScalarField& gradUPatch=refCast<fixedGradientFvPatchScalarField>(U.boundaryField()[patchID]);
Regards,
Stefan
boundary conditions, fixedgradient, neumann
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
