Particle position each timestep (during simulation) |
August 27, 2010, 06:32 |
Rep Power: 16 |
Hi, i have the following problem:
I need to know how many particles are there in the zone 1 and zone 2 of a room. An example: 10 meter long room (x direction), while the first 5 meters are the zone 1 and the other 5 meters are zone 2. The particle position file outputs the coordinate (x y z) of each particle, so it will be like: if x < 5, sum to zone 1, else, sum to zone 2 The actual output while solving the uncoupledKinematicParcelFoam is Cloud: kinematicCloud Total number of parcels added = 1210 Total mass introduced = 1.01368723e-17 Current number of parcels = 1210 Current mass in system = 1.01368723e-17 ExecutionTime = 0.61 s ClockTime = 1 s and my objective is to add the following Current number of parcels in Zone 1 = xxx Current number of parcels in Zone 2 = yyy Is it possible to make it in the solver? Or it's better to make a separate code to extract this information? By the way, i don't know c++ programming =( Thank you, and if anyone needs I can send the room from Annex 20 with the uncoupledKinematicParcelFoam working. PS: Using OpenFOAM 1.7.x |
September 10, 2010, 00:58 |
edison
Rep Power: 17 |
rather than modify the code, you can acturally find the particle position under time/lagrangian/postion. sort them in the dirction of interest in Excel or matlab. Then your answer would be obvious.
September 10, 2010, 03:22 |
Rep Power: 16 |
Thank you for the answer Edison, this really works for simple cases if there is not many zones.
But the problem is to have more 3D zones where the coordinates are complicated. I did a simple fortran code and its working by the moment. Thank you for the tips |
lagrangian particle |
Particle Trajectory calculation | yueroo | FLUENT | 2 | July 13, 2009 13:32 |
Display Particle Position on a Plane | Jana | FLUENT | 2 | July 13, 2007 02:46 |
Timestep for transient simulation | houman | CFX | 2 | April 28, 2005 03:44 |
timestep for combustion simulation | yangqing | FLUENT | 0 | August 18, 2002 08:46 |
Particle Trajectory calculation when particle hit | yueroo | FLUENT | 2 | February 28, 2001 04:26 |
