particle number concentration in OpenFOAM
Like Tree2Likes
Old   July 8, 2016, 18:13
Gina M.
gmag is on a distinguished road
Originally Posted by wentao View Post
In the main code, I assigned kinematicCloud.rhoEff() to pncon as follows.
pncon = kinematicCloud.rhoEff();
runTime.write();
It is compiled successfully.
I am interested in applying Wentao's solution to my problem, but I have a question:
Is the best place to insert this code in the main part of the application code? Or is there a more general solution?
Thanks for your help!
gmag is offline   Reply With Quote
Old   October 12, 2016, 16:38
Alberta
Ela89 is on a distinguished road
Hi everyone,
I'm also trying to find the number of particles that impact a surface (particles that rebound). Does anyone know of a way to do this?
Thanks!
Ela89 is offline   Reply With Quote
Old   October 12, 2016, 21:17
Ping Chang
chpjz0391 is on a distinguished road
Originally Posted by Ela89 View Post
Hi everyone,
Thanks!
Hi Ela,
You can achieve this goal by paraview. In the paraview, you can select all the particles which on the surface of your model.
Kind regards.
Ping
chpjz0391 is offline   Reply With Quote
Old   April 12, 2017, 18:39
Karelke Yu
cfdopenfoam is on a distinguished road
Originally Posted by chpjz0391 View Post
Hi Ela,
Kind regards.
Ping
Hi Ping,
Thank you for your hints here. Could you be a littile more specifically how this can be done? I am working with the solidParticle class.
cfdopenfoam is offline   Reply With Quote
Old   April 12, 2017, 19:30
Karelke Yu
Hi everyone,
Thanks!
Hi Alberta,
Did you solve your problem? Could you pls post your solution here? I am facing the same situation.
Thanks.
Old   October 23, 2019, 22:31
Hailong
nilvxingren is on a distinguished road
Hallo, Marta
With your help, everything seems clear. But I still want to confirm whether what I have done is right or not!
Take that piece of code you referred to as an example. Function rhoEff() is declared in KinematicCloud.H but defined in KinematicCloudl.H. At the same time KinematicCloud.H is inserted into basicKinematicCloud.H which is applied in my main code as follows.
#include "fvCFD.H"
#include "basicPsiThermo.H"
#include "turbulenceModel.H"
#include "basicKinematicCloud.H"
Therefore, rhoEff() can be regarded as a member function in basicKinematicCloud.H. And then I create an object for basicKinematicCloud class, named kinematicCloud.
In the creatField.H, I also build a volScalarField variable named pncon.
Info << "Reading field pncon\n" << endl;
volScalarField pncon
IOobject
"pncon",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
mesh
runTime.write();
Hi wentao, I try this this method ,but get an error "cannot find file file: /mnt/hgfs/1ShareFolder/coalcutterLES/0/pncon at line 0." when I run my case. Is it necessary to create an initial pncon file under the 0 file? thankyou
nilvxingren is offline   Reply With Quote
Old   June 17, 2020, 09:15
Ferdinand Pfender
FerdiFuchs is on a distinguished road
you could modify the voidfraction from cloudfunctionsobject. thats what i did and it works pretty good. Thats how i calculate particles/m³ per cell.
regards,
FerdiFuchs
FerdiFuchs is offline   Reply With Quote
Old   March 20, 2022, 23:43
Default reactingparcelfoam droplet heat interaction with the walls
  #48
RAJ GAURAV
RAJ_GAURAV is on a distinguished road
Originally Posted by Alaska1964 View Post
Dear Mayank,
Did you find answer for your problem? I have the same problem.
I am simulating droplets in a L shape channel. I am using the following conditions:
patchInteractionModel localInteraction;
localInteractionCoeffs
patches
WALL
type rebound;
e 1;
mu 0.9;
In my log file it is reported that:
Parcel fate (number, mass) : patch WALL
- escape = 0, 0
- stick = 0, 0
I want to count the number of droplets deposited on the wall. Ho can Count it ? Shall I add a specific command in kinematicCloudProperties to show the number of droplets deposited?
Cheers,
hii everyone
i am using reactingparcelfoam and injecting mist with path injection but it is not interating with the plate which i want to cool down. can anyone suggest some methods to enble the heat transfer of droplets with the walls.
RAJ_GAURAV is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
Particle Tracking Batis CFX 2 October 6, 2010 15:20
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
particle courant number Michiel Siemens 1 August 10, 2003 05:50
