fixedMeanValue execution problem
Old   November 10, 2010, 02:42
Unhappy fixedMeanValue execution problem
siddharameshwara is on a distinguished road
Hi to every one,
I am trying to include fixedMeanValue boundary condition to cavitating Foam solver when i execute it .It is showing the following error could any one help me in this regard
Making dependency list for source file cavitatingFoam.C
SOURCE=cavitatingFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/transportModels -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/transportModels/incompressible/lnInclude -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/transportModels/interfaceProperties/lnInclude -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/turbulenceModels/incompressible/turbulenceModel -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/barotropicCompressibilityModel/lnInclude -IlnInclude -I. -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/appl/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc43DPOpt/cavitatingFoam.o
In file included from cavitatingFoam.C:46:
fixedMeanValueFvPatchField.H: In function ‘int main(int, char**)’:
fixedMeanValueFvPatchField.H:42: error: ‘namespace’ definition is not allowed here
In file included from fixedMeanValueFvPatchField.H:176,
fixedMeanValueFvPatchField.C:32: error: ‘namespace’ definition is not allowed here
/appl/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/readPISOControls.H:11: warning: unused variable ‘transonic’
/appl/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nCorr’
siddharameshwara is offline   Reply With Quote
Old   November 10, 2010, 13:17
Stefan Herbert
herbert is on a distinguished road
in general, you must not add the #inlude below the
int main(int argc, char *argv[])
if you want to define a new class.
BTW: It would be better if you would create a own library out of fixedMeanValue and include this lib in your system/controlDict. That will prevent problems using paraview for postprocessing.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   November 11, 2010, 02:52
Smile
HI stefen,
I am new to this openfoam. I do not know the procedure you have explained.Could you please elaborate step wise with some what in detail.Because i don't know how to create lib and add to system controldict that you have explained.I would be grateful to you.
Thanks in advance
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 00:15
convergence problem Trushar Phoenics 5 August 27, 2002 23:40
